Toofah King Bad
Rasta Monsta's Avatar
T-Bar Merit Badge
Giving myself one. DIMED on attempt #1.
I also propose t-bar database. If everyone who installs non-stock t-bars takes one simple measurement, nobody will get it wrong again. . .ever.
Simply measure from the TOP of the banana arm to the CENTER of the hub ("H"), unloaded (off the car).
My contribution:
  • TBAR: 22mm, Swapped for 27mm
  • "H" MEASUREMENT: Originally 11 inches, modifed to 9 3/8 inches
  • RIDE HEIGHT ATTAINED: Freakin' Perfect
Enjoy!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-21-2010, 05:39 PM
darn..i didn't measure it one mine...but something's better than nothing
Tbar: 30mm
measurement: line up with original scribe mark, then 2 inner splines
ride height: 12" from hub center to top of wheel well.
Old 02-21-2010, 06:01 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
T bar?
I have no idea what you are talking about. But, IF you were to put a picture in with lines and arrows I would be happy to check it out.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 02-21-2010, 06:17 PM
Torsion bar...
Old 02-21-2010, 07:25 PM
Toofah King Bad
Bush voter, seriously considering contributing to Palin 2012.
Old 02-21-2010, 07:53 PM
Post of the week!
Old 02-21-2010, 07:54 PM
slodave's Avatar
If this keeps going.... It's going to be in PARF soon...
Old 02-21-2010, 07:58 PM
smokin_944's Avatar
Rasta, how long did the job take you?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 02-22-2010, 05:16 AM
944Spec_bound's Avatar
thats a good idea, use a set point of reference for measurement and share it. All the formulas and templates are good tools, but why not simplify it with A to B distances and be done?
1st attempt at mine, car ended up with stiffer bars but exact same height.
My point of measurement was similar to yours. But using the center of the hub had too much eyeballing for me, I wanted it exact. So I used a square, layed it on the inside part of the spring plate, aligned it with the end, and measured to the top of the banana arm.
Like this, I measured where I drew the red line:
My measurement this way:
T-BAR: before 21mm, after 28mm
L-MEASUREMENT: Before, didn't measure it, After 6 1/4"
RIDE HEIGHT: 3 1/2" at rocker with spring plate concentric centered (Raised it to 4" later)
Looks like this now:
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 02-22-2010, 06:22 AM
Toofah King Bad
It took a few weeks of off and on work, my best estimate at this point is 12-16 hours.
Tricky clickie pickies:
Old 02-22-2010, 06:37 AM
Oh, and the only merit badge I got was this:
My Website:
Old 02-22-2010, 06:42 AM
Toofah King Bad
Hey Spec_Bound, bet your insurance agent LOVES that license plate.
Old 02-22-2010, 06:44 AM
I hope he never sees it! But I figure I'd call it my Level 1 warning, Level 2 would be horn, Level 3 is #44 comin atcha.
"I warned him," probably wouldn't hold up in court, though.
My Website:
Old 02-22-2010, 09:52 AM
Az 944 Spec Director
M758's Avatar
By the sound of it you used a little spreadsheet to help out.
Glad it worked out well.
Personally I am 2 for 2 in t-bars.
once from 23 mm to 28
then from 28 to 30.
BTW... my reference measuments are "default" values in the speadsheet.
Joe P.
88 944 Turbo S - 100% Stock 84 - 944 Spec #94 Red/White
Arizona Region 944Spec Director
Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 03,04,08,09
4th - 2009 NASA Natls - Fastest 944 spec lap at Miller Natls - 2.19.282 (Sat Warm-up)
Old 02-22-2010, 10:51 AM
M758's Avatar
The speadsheet floating around uses the measurement to the center of the hub. The red lines show above are not referenced in the spread sheet and due will not give you the same number due the angle of the trailing arm. Also it is not possible to do a ride height change measurment location at this point without math due to the angle.
That is why I used the center of the hub.
If you want accurace you can used a carpenters square at the hub or use make a piece of cardboard that fit in the CV joint hub. Mark the center of that and use it. I did that when I did my 2nd t-bar job to make it easier. I just never took a picture of it.
Joe P.
Old 02-22-2010, 10:57 AM
Joe's spreadsheet is an excellent tool, and the pic I used was altered from his original.
So, to clarify, my 1st attempt was hosed because I DIDN"T use the spreadsheet, and tried shortcuts that took twice as long, then had to find a way to make a static measurement.
Sorry, didn't mean to suggest any negative about the spreadsheet.
Do it once, do it right, drop the whole rear assembly, use the spreadsheet!
My Website:
Old 02-22-2010, 11:20 AM
M758's Avatar
No offense taken.
Im just happy it has worked out. I created that for myself back in 2002.
Joe P.
Old 02-22-2010, 11:23 AM
Toofah King Bad
Yep, spreadsheet worked like a charm. . .but like I say, if everyone measures "H" in a uniform way, soon nobody will need the spreadsheet or its multiple measurements.
Old 02-22-2010, 02:48 PM
M758's Avatar
Well not really.
The fact is everyone's car is a different weight. The compression of each t-bar is fixed based in the diameter of the bar and a constant car weight. However cars are never the same weight.
My car is 2450lbs or so without driver. Stock curb weight by the book is 2779. So a stock weight car will compress more (requiring a long "H") than my lighter race car.
Not only that I run my car very low, much lower than for a street car. Again my "H" may not bee you "H".
That is why the sheet attempts to determine a baseline spring compression and then figures a delta for the new t-bar. This assumes the weight of the car remains the same pre and post t-bar change.
Joe P.
Old 02-23-2010, 04:45 AM
it would be really nice if the spreadsheet was updated to factor in the 9 and 8.8 degree thing so that u could put in a desired height, and it'd give u how many splines of each u'd have to move to get as close as possible to that target.
Old 02-23-2010, 05:04 AM
