just died
some of you are familiar with my (3+ year) project by now. she was running like a champ. now, no start. i am suspecting bad gas. i was bringin her up to temperature whan all of a sudden she started running rough and died. i have been putting off replacing fuel and filter
i pumped some fuel into a glass container and it seemed alright. anyway, i still have spark, injectors are firing, tach is bouncing...additional info: plugs are wet, starter fluid does nothing ![]() i waited overnight sprayed starter fluid and i do get an occational "pop" ... any thoughts (besides "i am a moron who should have cleaned out his tank long before running a new engine")
1988 944 turbo |
Old Guy
First thing i would do is change the plugs could be fouled
1963 Corvette 1969 Z/28 DZ 302 Silver & Black one owner me 1991 Mazda Miata 2011 F250 {work truck] 2011 Sicon XB LE [Wifes Car] 1983 944 Slant Nose Wide Body [Mine] |
Custom User Title
You're gonna laugh but maybe if the car's been sitting for quite a while, maybe you should check the air box/air filter for obstructions.
My son and I just ressurected an 88 NA that's been sitting for seven years. When we started it, it idled okay for a while, then we turned it off. The next day, we started it again. I reved it a couple times and then it started running badly and died. We were frantic, thinking we'd screwed something up - we'd just replaced four bent valves and done a belt job. We checked and rechecked everything. Finally, I sarcastically suggested maybe we should check the air box for rats nests. Amazingly enough, that's what we found! A rat (or some small animal) had crwled in through the cold air intake and had chewed through the filter and made a nest in the airbox. It was disgusting! When I revved the car, it had sucked part of the nest into the throttle body. We cleaned it all out and managed to get the car started again. After maybe 5-10 minutes, it ran fine again. I dunno if you would ever find anything quite that dramtic, but it never hurts to check... If you have spark, the plugs are wet and starting fluid does nothing, that does suggest an obstruction.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Twuz a loose rotor. Got it!
1988 944 turbo |
"Dude! You kicked my car.
Custom User Title
The cheap easy fixes are the best fixes!
