Just thinking out loud
mattdavis11's Avatar
Unhappy ??? about 944 Steering
I had an unfortunate situation in my '83 944. Rain washed a rock in the road, about 9 inch tall. Missed my air dam,& rad (how i have no idea) but got the sway bar, oil pan, and the K plate is split in two. My question, are the 924 front end suspension and steering the same as a 944 w/ manual rack? Will a 924 sway bar work on a 944? Anyone have a parts car with these parts? Anyone possibly looking for a parts car? Motor, trans, body still in great shape!
Old 11-29-2001, 12:49 PM
How many miles do you have on the motor?
Old 11-29-2001, 01:11 PM
The motor has 115,807. The valves, timing belt, etc... were changed 2,000 miles ago. not even enough time to change the oil.
Old 11-29-2001, 01:21 PM
I think the cross member & steering rack are diferent, but reat of the suspension is the same on the 5 lug 924.
Andrew Love
Old 11-29-2001, 05:54 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
I have a 'used' cross member I don't need. I can let you have it...
With the right caster bushings, and original Porsche front bushings, it's fully and totally usable.
Contact me if interested.
Ahmet
Cheers!
Old 11-29-2001, 06:02 PM
milage
Thanks for the info. I only have 49,000 on mine, so I'll stick with it. I've been toying with the idea of a new motor only because I have a very very small, slow, and steady oil leak (less than half a quart per month) that will be an evil beast when it grows up to a full-grown leak.
Jake
Old 11-30-2001, 05:11 AM
