Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
kilodawg's Avatar
Leaking air sound while depressing brake pedal
Tried searching for this but no joy. This evening I noticed an air leaking sound while pressing down on the brake pedal. The sound occurs while the pedal is between about 1/3 and 2/3 depressed and seems to come from the pedal area itself. It goes away when fully engaged and brake performance seems unaffected. Any ideas?
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 03-04-2010, 05:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
sounds like a leaking brake booster. Its the "power assist" part of the brakes. Its the large black round part that the brake maser cylinder is attached to
Old 03-04-2010, 06:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
kilodawg's Avatar
The little I read indicated that a leaky booster would result in a stiff pedal mine is no different than before. Is that a bad assumption?
Old 03-04-2010, 06:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Proprietoristicly Refined
John_AZ's Avatar
I replaced the brake booster on my '98 Cherokee last year.
I had a sucking sound when I pressed the brake pedal.
You chould check the booster air check valve for operation but it is most likely a leaking diaphram in the booster. Check all your vacuum lines.
Here is a simple check I did. There are many more if you search.
Vacuum Boost
Check to see what brake MC you have and if you are lucky it will be the ATE.
Porsche 924S/944/968 Brake Hydraulics - Page 2
GL
John_AZ
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 03-05-2010, 04:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
