Exhaust question
Hello,
I replaced the muffler section on my 944 tonight and have a question regarding the connection to the cat pipe. Is there supposed to be a gap between the two pipes or is it flush? I have about a quarter inch gap so I'm not sure if I did it right or perhaps the sealing ring is in wrong as I can't tighten the bolts any further. Any help would be appreciated.
Old 03-08-2010, 11:03 PM
Az 944 Spec Director
M758's Avatar
there is a gasket in between and the tubes should be flush. The flanges might not be.
Joe P.
88 944 Turbo S - 100% Stock 84 - 944 Spec #94 Red/White
Arizona Region 944Spec Director
Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 03,04,08,09
4th - 2009 NASA Natls - Fastest 944 spec lap at Miller Natls - 2.19.282 (Sat Warm-up)
Old 03-09-2010, 06:53 AM
ernie9944's Avatar
=That sealing ring or doughnut is a PITA to line line up ,sometimes if you order a new one it won't be excatly the same size as the old one I wouldn't worries to much about a " gap if it's not leaking .Cause when I replace mine that about the amount of gap I had didn't bother trying to close it tigth cause it's almost impossible .
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-09-2010, 07:58 AM
Thanks for the replies. Sounds like its ok so I will leave it alone. I just could not remember if it was flush or not.
Old 03-09-2010, 09:22 AM
