944 stuck in 5th gear
Will not shift into any other gears, is my transmission shot?
Work just fine and all at once will not shift cannot even force it to, I am hoping it is the linkage?
Old 05-12-2011, 06:05 AM
Porsche Addicted
bnv944's Avatar
is you clutch pedal unusually soft? if so you slave or master cyl prob blew a seal.
if the shift knob moves into all "gears" but car is still in 5th its most likely your linkage- theres a bolt that connects the rods right in front of the transaxle.
*1987 944 n/a. project car.
*1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert
*2001 Jeep wrangler SE - THUMPER
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 05-12-2011, 06:19 AM
Clutch is pretty soft, since I am a new first time 944 owner, not quite sure.
I have had the car for 2 days, it has not run in 5 years! I got it running in 4 hours.
It drove and seem to have shifted fine prior to this incident. So, I am guessing that the slave blew like you said. I am and engineer and a mechanic from nuclear navy on sub so I am think I am qualified to do this restore.
Thanks I will check the linkage and the slave tonight.
Old 05-12-2011, 06:27 AM
Useful sites for help with DIY projects
Clark's Garage Home Page
Home - Porsche 944 Turbo (951) - texasblake.com
Bennington Motorsports
Tech Articles
Good Luck
88 944 na
07 335i
12 Cayman
Old 05-12-2011, 11:26 AM
Porsche Addicted
bnv944's Avatar
rollyy, do you by chance work on the groton sub base? you actually might know my father haha
Old 05-13-2011, 05:02 AM
