mistertate's Avatar
Originally Posted by ernie9944 View Post
Sorry Andat hope your not thinking I'm stealing your treads but I got to respond to this guy can't help it, you want Porn- misterstate- there you go -924 GTR image
ya totally, 3.0 from that 924 GTR a while back. Notice the intake cam on that is exhaust or or 928 intake cam (?) with the keyway sticking out. Milledge and Raetech have had some stuff. I just wish someone would figure out how to do it affordable, I guess it will have to be me.
dude
Old 03-28-2010, 12:34 AM
flash968's Avatar
i just saw one yesterday, and wished i had my camera - it was a 968 engine with a full log ram setup - turbocharged, dry sumped, and all the bells and whistles, but 650hp
Old 03-28-2010, 05:36 AM
ernie9944's Avatar
Another 16V porn pic .I find this one discusting.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-28-2010, 08:09 AM
The OP intake still looks dirty to me...definitely not "intake porn"
1992 Porsche 968 (VW 07k 2.5T swap in progress)
2003 Audi S8 (Avus/Oxblood)
1986 Audi Coupe GT (20v 2.3L swap)
1983 Audi Ur-Quattro (20vt swap in progress)
2010 VW Touareg TDI (DD, tow rig)
Old 03-28-2010, 09:46 AM
flash968's Avatar
that's the huntley kit - i didn't think there were more than the one that is on a friend's car right now (we're trying to get it running right, and undoing a lot of junk other shops did)
whose car is that?
Old 03-28-2010, 11:12 AM
ernie9944's Avatar
whose car is that?
Don't know who it belong to can't remember , Flash is this your friend car with the huntley's kit the owner is from CA.
Old 03-28-2010, 01:36 PM
Endat's Avatar
looks pretty clean to me.. still due for a final sandblasting and then powdercoat.. i'm using red masking screws to make sure the brackets go back on smoothly
Old 03-28-2010, 01:41 PM
flash968's Avatar
ernie - no, that is not my friend's car - his is a 968 - it used to belong to tony garcia - we are pretty close to having it sorted out - like i said, we just had to undo a bunch of stuff some "experts" did
pretty typical "turbo mentality" stuff - "hey - let's throw big injectors and a standalone at it - that'll make it go" - all it does is run fat and cost a lot of money
then let's throw a big intercooler on it, but stick it way out front at the grill so all it does is create turbulence behind it, and preheat the radiator - didn't anybody teach them that you at least have to mount things like that very close to the radiator to make for efficient flow?
the minute i changed the intercooler to a 951 unit, and then put it in a place clear of the radiator flow, i picked up a pound of boost and dropped intake temps 40 degrees
now we are going back to the stock injectors and ecu, and doing proper mapping, instead of just throwing a bunch of fuel at it
with about 5lbs boost, we figure to see big torque down low where we want it, and a nice bump in overall power, but be very streetable, and most importantly, start and idle, as well as not run hot
i wonder if it's the same supercharger?
Old 03-28-2010, 03:18 PM
You should get some silicon plugs:
I just did my intake a few days ago:
Old 03-28-2010, 04:00 PM
rickharrison's Avatar
That 2nd pic looks like "bluecamaro"'s ride from Renny.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 03-29-2010, 06:21 AM
ernie9944's Avatar
Rick it is "bluecamaro" from RL his is a very nice set up & well done compare to the other guy ,but I believe the first one the guy fabricated most of the parts himself hence a rougher looking job.
Old 03-29-2010, 06:36 AM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
ernie9944,
I swear that pic looks like a Huntley or maybe a Lindsey Intake plenum, but it looks like it's sitting on a supercharger!?! Who's car is it? and where can I see it. I want Santa to bring me an SC just like dat!
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 03-30-2010, 10:01 AM
flash968's Avatar
it is a huntley - it is on top of an SC - it could even be the very same setup that is now on a car i am working on, and should have done in the next couple of weeks
funny - i am doing 2 supercharged 968s simultaneously, one roots, the other centrifugal
Old 03-30-2010, 10:55 AM
cjpacitto's Avatar
Originally Posted by Endat View Post
Thanks! it was assorted wire brushes and a drill... it will be powder coated gold along with the valve cover and the cam belt cover... I LOVE GOOOOOOLD!
HOLY CRAP what a miserable task this is. I started out first thing this morning and mine still isn't stripped. First I tried soda blasting and that was worthless... it didn't take much off at all. Then I tried aluminum oxide blasting which was ok but very slow. Then I tried some wire wheels which were better but not great. Finally I pulled out a grinding disk and that kicked ass but couldn't get into many of the tight spots (there are tons of tight spots on these manifolds). That was followed with wire wheels again and then back to aluminum oxide blasting. It's getting there but I still have an hour or two worth of work to go before it's completely stripped.
If anyone else tries this I recommend getting a good chemical stripper first. It appears that these have 2 layers of powder coat... the stock bronze color with a black powder primer under it.
Old 04-03-2010, 04:13 PM
Endat's Avatar
What I did was work the brush at full speed (3500rpm) very slowly and gently along the surface in a similar fashion to mowing the lawn. I got impatient and used force a couple of times, which left a few scar marks and ate off some of the part number written on the top. I used the brass brush set that has 3 different sizes and found myself switching bits frequently and using different angles of attack. Took me about 6 hours total, best thing to do is just zone out... you REALLY need a dust mask for this if it's been repainted before, because of lead dust and poison and stuff.
My workshop told me about a stripper called Aircraft Remover, but warned that it would eat into the aluminum if not careful
Old 04-03-2010, 05:57 PM
Endat's Avatar
oh yeah, you cant grind all the paint off because of the tight spots... those need to be blasted with sand or chemicals
also you should peel what you can of the paint with a really sharp knife, i scraped it with a dagger and a lot flakes right off.. the black undercoat is probably just aluminum oxide, looks better when its gone
Old 04-03-2010, 06:03 PM
cjpacitto's Avatar
Got er done!!!
Took all god damn day but it's done. The color is "wrinkle black"
Old 04-04-2010, 06:00 PM
Endat's Avatar
That is freaking awesome looking! it looks like that rhino lining you put in truck beds. Looks like you used masking screws too... nice job!
Old 04-05-2010, 08:02 AM
ernie9944's Avatar
Thumbs up
Nice Job send us pics when install PS.
Old 04-05-2010, 08:08 AM
Roman944's Avatar
hey guys, what would be the steps to get my intake manifold look red like that? never done this before
and camshaft housing?
I have all these off for cylinder head job right now, and it would be nice to get the engine bay cleaned out a little bit
I was also thinking of red silicone coolant and vacuum hoses
could be too much red? lol
Old 04-05-2010, 12:35 PM
