jamesjedi's Avatar
WTB Coil overs for 86 944
WTB Coil Overs for an 86 NA.
jamesconnelly1@yahoo.ca
Old 03-25-2010, 09:32 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Are not they all "Coil Overs" unless you are speaking of rear shocks - What are we talking about here ?
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 03-25-2010, 12:35 PM
jamesjedi's Avatar
Yes, I need rear shocks, and I need the struts as well! I am sure you know what I mean. I want to do a torsion delete.
Old 03-25-2010, 01:50 PM
well if you wanted to be technical, no they aren't all coil-overs . what we have on front are conventional McPherson struts, coil over has the coil's on the strut itself not a separate part. not to mention to all wonderful multi adjustment point's it adds
1983 944 Guards Red (87' Implant Complete)
Old 03-25-2010, 07:21 PM
Garage Helper
So just how do you mount your springs if they are not mounted on the struts ?? Springs and struts come out together don't they ??
Check with Paragon for the rear coil over combos they have - a little spendy but they do the trick. Even searching other places for them they are all priced close to the same range...
Porsche 924 944 968 Suspension Shock Strut Sway Bushing
Old 03-25-2010, 09:55 PM
jamesjedi's Avatar
I have posted two WTB's in my search for coil overs. I wll probably get the Paragon Koni kit for front and rear. It is priced at $100 off. Also, once everything is priced seperately, it looks like a good deal. New shocks vs. old shocks/struts/springs is also appealing.
Old 03-26-2010, 02:45 AM
