Fuse-ing: Washer Fluid Pump
I've checked the forum history, and found some conflicting info about washer fluid pump fuses (86NA).
This post (Windshield washer fluid pump isnt working.) suggests there is a fuse for it,
BUT
Clark's fuse diagram doesn't include a fuse for the washer fluid pump. I'm trying to diagnose why the pump isn't getting signal (pump runs fine when wired), and this was suggested as a possibility.
Also, in case I need spares, any suggestions on where to buy the fuses?
Old 03-25-2010, 09:17 AM
Resolution: There is no fuse for the fluid pump, but other posts suggest cleaning the contact on the column.
Hotwired mine straight to the battery to confirm it was working, turned out to be a clamped hose preventing fluid from traveling. Easy fix!
Old 03-29-2010, 07:25 AM
