ewalt98's Avatar
Roof edge strip removal
Quick question..
I believe the roof edge strip mounting tab is bent down over the driver's door which is causing the top of the door to bind a bit on the trim upon closing of the door (damaging the rubber seal at the top of the door). So, I would like to pull the strip off and bend the mount tab up a bit.
Has anyone advice on removing the trim without damage to either it, the sealing rubber, or the roof? I'm sure it is a matter of prying it off, but, it would be nice to hear from others who have done it before I attempt it.
I think the part number is 944 559 705 00, if my description isn't clear.
Eric
1985.5 944
Old 03-28-2010, 09:04 PM
ewalt98's Avatar
Update; decided to work on removing it last night.
The trim piece is aluminum and is held on by some clips attached to the body via post and slot. Taped up a flat screw driver and began to pry it straight out. Does not easily pop off, but with some work, it can be removed without damage.
Goes on much easier!
Old 03-30-2010, 06:48 AM
