Question K & N or stock air box?
I would be interested in hearing from anyone regarding the use of a performance air filter on a 944 2.5L engine. This is a basic upgrade that would increase the performance of the engine right? Not according to a 944 racer that I recently talked with. According to the racer, he experienced a slight HP drop when the K & N filter was installed. In addition the filter paper should be dry, the oil from the K & N gets in the throttle body. Has anyone had a similar experience?
Old 03-30-2010, 04:00 PM
jonvo's Avatar
Stock air box is supposed to be the best. It's a cold air with a large surface area filter.
Cold air intake?
Old 03-30-2010, 04:05 PM
stick with a Mahle Microstar...K&N claims are way overblown and they do indeed allow fine particles through the media...you won't notice a difference in the butt dyno but your engine will thanks you.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 03-30-2010, 04:06 PM
Toofah King Bad
Rasta Monsta's Avatar
We need a sticky thread at the top of this forum.
HOW CAN I GET A BIG, CHEAP, BOLT-ON HORSEPOWER BOOST FROM MY 2.5 NA?
Answer: you can't.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-30-2010, 04:32 PM
Proprietoristicly Refined
John_AZ's Avatar
solex is referring to the the stock air filter replaced with a K&N air filter and placed inside the stock air box.
This may have merit because I have used a K&N air filter that is sprayed with K&N filter oil. It is supposed to be washed and cleaned on a regular basis.
If the filter is oversprayed with K&N oil it may do what solex mentioned.
The oil could get into the TB or the ICV/ISV and clog up passages.
Bad AOS seals could do the same and blame could be placed on the K&N air filter.
Now I will go out and clean my K&N air filter....
John_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-30-2010, 05:22 PM
PRMN944
You can buy the K&N air filter panel stock replacement at AutoZone and
try it out to feel the difference between the stock and K&N. If you are
not convince that engine breath easier and its performance greatly
improve, return it to the store in its original box and get your refund
after test drive.
I used it on my 1983 Porsche 944 NA since 1995. The filter is already
pre-oil that will last to 30K miles or more before cleaning.
Old 03-30-2010, 07:53 PM
On Boost
Paulyy's Avatar
I have a K&N pod filter on my turbo, i did notice some dust particals in the intake pipe, but my filter was dirty, that reminds me i need to clean it again
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 03-30-2010, 08:14 PM
Stock air box or K & N
I don't want to pick on K & N, or any other filter, but according to this source the stock air box setup results in better performance for this application. The reason is that the air box provides a source of cooler air, the performance filter only sucks in hot engine air.
Old 03-31-2010, 03:11 AM
John_AZ's Avatar
Cold air intake?
jonvo had it right. solex is referring to the K&N CONE
Old 03-31-2010, 05:23 AM
flash968's Avatar
intake temp and surface area determine the largest part of whether or not any filter works better than another for power - all other things being equal, put a bigger filter in a colder spot and the engine will perform better than with a smaller filter in a warmer spot
Old 03-31-2010, 06:16 AM
Answer: you can't.
yea there is. giggle gas
Old 03-31-2010, 06:40 AM
