ideola's Avatar
late offset rebuildable strut housings???
Were there ANY o.e. strut housings after 1985.5 that had removable gland nuts such that the strut insert can be replaced without requiring the cut-and-bolt method?
I've done a bit of searching on this issue, and I'm getting conflicting information in various threads. I've seen a few references where folks claim to have late offset cars that had removable strut inserts, but I haven't been able to isolate it to a particular year or trim level. Also, I have a set of late strut housings at home that appear to have a gland nut. They don't look like these, which are obviously the sealed variety:
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 04-01-2010, 09:45 AM
I've not seen one. Probably only seen around 100 pairs of late struts in total.
Good luck, George Beuselinck
Old 04-01-2010, 10:23 AM
Toofah King Bad
Rasta Monsta's Avatar
How do you know they are late housings? I don't think rebuildable late struts exist.
*EDIT*
Oh wait, I have some '86 951 housings that LOOK like they have a nut, but it isn't actually threaded.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-02-2010, 02:59 PM
ideola's Avatar
The ones I have are definitely late, they have the 63mm spacing at the mounting point, still have the ABS harnesses attached, and the late style upper strut mount. I think they're not rebuildable, will have a closer look this weekend. Looks like I may have to break down and figure out how to modify early ones to fit late spindles.
Old 04-02-2010, 04:00 PM
Toofah King Bad
Is there a reason you don't want to do the Koni rebuild?
Old 04-02-2010, 04:02 PM
ideola's Avatar
I already have a set of adjustable konis with ground control coil over setup configured for early strut housings, so I was hoping to use them and avoid the extra cost of buying new and the hassle of having to try to sell the ones I have. It wasn't going to be an issue until I happened across those 968 baby brembos
Maybe I should pull the koni inserts out that I have and see if they could be used with the bolt in approach on the late struts...but I got the impression that was a special setup.
Old 04-02-2010, 04:25 PM
Toofah King Bad
Ah, I hear ya. You are right, the bolt-in inserts are specially made. FWIW, Paragon will install the hack n bolt setup pretty cheaply. . .
Old 04-02-2010, 04:35 PM
ideola's Avatar
Yeah, I was looking at that, and if I can't find a way to safely modify what I have, I may end up having to sell it to subsidize buying the Paragon stuff.
Old 04-02-2010, 04:47 PM
Toofah King Bad
Here's an idea. . .since you'll be needing a new ARH kit for the late struts, and the springs are the same, you could get race-level springs with your new kit so you can sell the earlies to a spec racer.
Old 04-03-2010, 09:40 AM
