West Central Ohio 45380
plyhammer's Avatar
What all needs switched to go from 86 to 87 suspension wise?
I have a guy that wants to switch from an 86 to an 87 951 suspension. I think I know most of it. What can stay and what needs swapped? Thanks all
Old 04-04-2010, 09:02 AM
Under the car
I think that in the front it basically needs everything, control arms, spindles and struts. I think the brakes will still work.
In the rear I think all he needs to do is swicth the rear hubs to the late offset hubs and change the rotors to the deeper hat rotors. I just did the rear swap from early to late offset expecting to find different rear arms and all but the aluminum arms were the same and the only difference I could find anywhere was the hub and brake rotor.
Old 04-04-2010, 07:51 PM
Toofah King Bad
Rasta Monsta's Avatar
Odd job to spend cash on. Is he looking for a different wheel offset?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-05-2010, 02:54 PM
plyhammer's Avatar
Yep, He wants more choices. Thanks
Old 04-05-2010, 09:18 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Doesn't like spacers ?
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 04-05-2010, 09:33 PM
