Won't start
I've been having issues with my 944 but it always started, just would take awhile.. Yesterday I had the dme coolant sensor unplugged and when to go start it and it started fine, idled but then it died out.. And now I can't get it to start at all. It has fuel/spark, so I don't get why all of a sudden it won't start.. Any ideas?
Old 03-23-2010, 06:27 AM
On Boost
Paulyy's Avatar
try fiddle with the coolant sensor plug, might not be in right or be dirty. if that sensor does even effect the engine
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 03-23-2010, 07:01 AM
Proprietoristicly Refined
John_AZ's Avatar
When you "unplugged the DME coolant sensor plug" and tried to start it.....
Did you just leave the bare copper tip dangling on the block and possibly shorted out the DME?
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-23-2010, 07:34 AM
Nope, I may be dumb but not that dumb lol.. And I didnt recall it being bare it has that plug plastic cover around the connection prongs. I replaced the DME and MAF today and still no luck..You can hear/feel the engine like it wants to start but does not. When I check the plugs they are covered in gas and black.. I also replaced the speed/ref sensors. Spark is strong
Old 03-23-2010, 10:15 AM
Is there a way I can check the speed/ref sensors? I always thought if I was getting spark they are working
Old 03-23-2010, 04:21 PM
John_AZ's Avatar
First check the tach on the dash, when you crank the engine does the needle bounce 1/16 of an inch. OK-then usually good.
OR
Speed and Reference Sensors - Checking, Replacement, and Adjustment
GL
John_AZ
Old 03-23-2010, 04:27 PM
It's an '83, was told they don't do the tac bounce?
Old 03-23-2010, 04:29 PM
John_AZ's Avatar
I reread Clarks and no mention that an '83 was different in regards to the tach bounce.
Old 03-23-2010, 04:39 PM
Hmm ok I never noticed any tack bounce though even when the car ran
Old 03-23-2010, 04:56 PM
i have a 83 as well, the tach will bounce noticeably when cranking. if yours doesnt try switching your reference sensor plugs on top you may have them backwards
1983 944 Guards Red (87' Implant Complete)
Old 03-23-2010, 06:29 PM
Will do, would it start if they were backwards though? I never messed with the plugs and the car was just running few days ago
Old 03-23-2010, 07:02 PM
Custom User Title
mikepellegrini's Avatar
No it won't run if the speed sensor plug is plugged into the reference sensor, etc.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 03-23-2010, 07:54 PM
yea lol scratch that idea, forgot if the sensors were switched it wouldnt start, if you need to replace one of them theres a bmw one that fits with same connection and all thats much cheaper than oem. or find a good used one
Old 03-23-2010, 10:30 PM
Do you know which BMW works? I'm going to a junk yard today and they are alittle more easier to find there than a Porsche lol
Old 03-24-2010, 04:36 AM
John_AZ's Avatar
smanna714,
B4 U rush out and crawl over a few greasy shells, follow Clarks testing procedure for the sensors. Its a simple resistance check. It will also help at the junk yard to make sure you do not buy a dud with a no return policy.
Another suggestion is to take along the DME part number of your car and price a used in case you make a return trip. Usual price on eBay is about $100 +s/h. Maybe post a WTB (want to buy) on Pelican parts for sale forum.
But here are a couple of links that have the cross reference information:
Parts Cross Reference - Rennlist Discussion Forums
http://www.alanara.fi/Possu/ENosat.html
GL
John_AZ
Old 03-24-2010, 05:25 AM
Yeah I just got to the house now that the car is at so I'm gonna start the testing and post back what I find.. I totally forgot my tach STICKS, so that would be why I never see a bounce..Usually I have to slap the side of the dash in order for it to start moving.
Old 03-24-2010, 06:32 AM
Alright heres results..
Speed Sensor = 1016 Ohms
Ref Sensor = 955 Ohms
So I take it they are fine? Since Clarks says 600-1600 Ohms? Im stumped now and have no idea what the problem could be....I was hopeing it was these but now I have no clue, I work on this car everyday, atleast 4 hours a day and this is how it treats me
Old 03-24-2010, 06:46 AM
John_AZ's Avatar
Just a couple of basic suggestions.
Is your battery up to a full charge with all the cranking you have done?
If you "slap" the tach now does it bounce at all when you grind the starter?
You said you have fuel and spark, did you try your spare DME relay or make a jumper per Clarks?
From the beginning, why did you work on the DME temp sensor? What problem were you trying to fix?
Clarks has a trouble shooting section:
Troubleshooting - Engine
balleysdad made up one as well. Includes many944s no start info:
Let start a NO START checklist
GL
John_AZ
Old 03-24-2010, 09:34 AM
Someone told me awhile ago to check the temp sensor. It tested bad thats why I replaced it..I just drained all the fuel out of it and it was brown and smelled nasty. I put new gas in but only about a gallon and a half. It seemed like it almost started but then it backfired thru the intake blowing the hose off.
I made a jumper relay and no difference, Battery is full was on the charger all night. Its only 3months old too
Old 03-24-2010, 09:40 AM
John_AZ's Avatar
Fuel, because it was dirty brown looking.
If the tank was emptied, did you replace the fuel strainer in the tank? (where the outlet hose goes to the fuel pump)
Did you at least replace the fuel filter?
Do you have an injector NOID light to check if the DME is sending a signal to the injectors?
Your injectors should be DIY cleaned (see Tech Info Center above ^^) or sent away to WitchHunter Performance - Injector Cleaning & Flow Testing Services for cleaning.
.....a beginning
Old 03-24-2010, 09:54 AM
