mikeran's Avatar
Cluster out, can start?
I have the cluster out to fix the odometer gear right now.
Is it safe to start the car to work on other things?
87 944 - Daily Driver - Son took it and now brought it back
Old 04-08-2010, 10:35 AM
Yes, of course, you won't have any indication if it has lost oil pressure, or the battery is overcharging, or you're overheating.
Good luck, George Beuselinck
Old 04-08-2010, 10:46 AM
Toofah King Bad
Rasta Monsta's Avatar
Check over your wiring diagram and make sure you don't have any hot and unprotected wires hanging down.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-08-2010, 10:56 AM
