kvnhpnr's Avatar
1986 944 Tranny
I have question about the automatic transmission in my 86 944 non turbo, I can feel the heat coming up into the car from the gear shifter and at times it gets hotter than others...why am I feeling that much heat coming thru the shifter opening?
Old 04-12-2010, 01:46 PM
Under the car
That heat is probably from the exhaust not the transmission. If you are doing a lot of sittting still you will probably get a lot of heat coming up through there. Driving you probably shouldn't get much.
Old 04-12-2010, 01:56 PM
Toofah King Bad
Rasta Monsta's Avatar
There is supposed to be a block of foam insulation surrounding the shifter, as well as a rubber inner shift boot. You may be suffering from loss of, or damage to either component, or both.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-12-2010, 02:22 PM
kvnhpnr's Avatar
1986 Auto Tranny
It heats up more when I am driving...is the foam/rubber boot around the shifter under the console?
Old 04-12-2010, 06:47 PM
