Anyone good with electrical gremlins?
ive got a problem with my passenger window not getting any power, neither the switch nor the terminals connecting at the motor. on driver side the switch has 5v on the terminals so somewhere between the switch and ???? theres a issue. anyone know where i should begin looking?
1983 944 Guards Red (87' Implant Complete)
Old 04-15-2010, 10:50 PM
I ties to figure out the switches out on my car using the diagrams in the FSM but coulden read them. I allways start simple then work my way up you might try making sure the switches contact points are clean and even opening the switch if it's posible and cleaning those realy good. Fixed a few and didn't fix others that way before.
Old 04-15-2010, 11:23 PM
yea that was my first try, but when that didn't work i too the measurements from the plug and got nothing
Old 04-15-2010, 11:27 PM
Per the diagram in my Haynes manual, your window controls should connect to the window control relay and then on into the fuses. If it is just your passenger side not getting power, you would need to check the connections on both switches for it, passenger and driver side. In past experience on other vehicles, a dirty or broken connection on one of the two will hold the circuit open. Confusing when you are looking at the good switch and everything looks fine.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-16-2010, 04:50 AM
