your average wrencher...
wire from where?
okay, doing the water pump on my 87 944 project and there are some wires right above it as you all know. I can follow the one set and they go to the oil pressure sending unit. BUT the others loop around and looks like the PO had a bread-tie attaching them right below the water pump. it only has one female connector( bullet type).
so what is it?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 04-20-2010, 05:41 PM
s928s's Avatar
I believe it is to an oil level sensor on the oil pan.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 04-20-2010, 07:44 PM
maybe is the lines for temperature gauge sensor.Your car must have two pin on it(one for show the temperature and one for the red light on it above 120? degreese)
someone put a different sensor with one wire?i did it on my car,84 engine in 86 car,different sensor.
the oil sensor have two lines also,one for red light and one for the pressure
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 04-20-2010, 11:39 PM
looked at it a little more, definetly one wire, but it has like a yellow silicone cover around it (like BRIGHT yellow) if this helps
1982 931 *project*
Old 04-21-2010, 06:42 PM
only "bullet" looking connector i remember connecting to my engine was the O2 sensor thats on top, and the oil level sensor on the bottom passenger side of oil pan above the drain plug
1983 944 Guards Red (87' Implant Complete)
Old 04-21-2010, 06:47 PM
must be the oil level sensor then.....
1982 931 *project*
Old 04-22-2010, 10:05 AM
