Release bearing help needed.
I can't seem to find a diagram or clear picture of the release bearing assembly.
How many rings in a release bearing setup, I have a total of 4, 1-Thin narrow, 1-multi-tooth, 1-thick, 1- C-Locking. is this correct? Thanks for your help. |
Garage Helper
By a search of this forum one can find almost any thing ...
How to remove throw-out bearing retaining ring? It is correct to have four shim/retaining parts with the Throw Out Bearing - They are installed a certain way - the serrated shim has to be facing the correct way also...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 04-19-2010 at 04:00 PM.. |
