dnasty007's Avatar
Porsche Crest my car sounds like
my car sounds like a remote contol car when i drive it is this normal even on reverse
Old 04-21-2010, 05:06 PM
What?
Parker Furer
1984 944 alpine white
Old 04-21-2010, 05:52 PM
Endat's Avatar
is it coming from the engine bay or the rear where the transmission is?
Old 04-21-2010, 06:03 PM
VII VII is offline
It's your belts causing that noise. Likely your balance belt is too tight giving it that sort of "electric motor" sound.
Old 04-21-2010, 06:51 PM
Endat's Avatar
^ +1 if its coming from the engine bay
Old 04-21-2010, 07:11 PM
Ornery Bastard
Reverse is a straight-cut, non-synchronized gear. It will whine like a summb*tch. This is common for almost all manual transmissions. If you're only hearing this sound in reverse then it's perfectly normal.
As others have said, these cars do tend to have belt whine as well. Even when the belts are adjusted properly, there will always be some belt noise, though if it is significant when at speed you should definitely have it checked as it could be an indicator that the belts are under excessive tension.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 04-21-2010, 07:16 PM
