SLED GUITARIST
Dan Himan's Avatar
Fpr
So I checked the fuel pressure on the 1985 944. I have had a gas smell, and its sle ow to return to idle. The pressure is high, 36lbs, when at idle. When i disconnect the vacuum line, it does not change, i also feel no vacuum on the line. I checked for leaks, no leaks, is this normal. Is it just a fauly FPR?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 04-22-2010, 02:36 PM
SLED GUITARIST
Dan Himan's Avatar
Ok P.O miss placed two vac lines. Now everything is reading correctly.
Old 04-22-2010, 03:51 PM
