ALLDATA.COM : Worth it???
Does anyone have any experience with AllData.com? They apparently supply TSBs online for many vehicles including the 944...
A one year subscription is $19.95. Their site is... http://www.alldata.com/products/diy/index.html BTW, do you notice the photo of the rear tailight on that page? Does the car look familiar? :-) Then again if someone has a PDF of all the TSBs for an 89 951 that they would like to send me, that would be cool too! Thanks. |
Hey, I have access to it through school. Not sure whether I would pay $20 bucks for it, but I can't say that it would be a waste of money. It sure has a lot of info. Anymore questions, let me know. Below is the list of TSB's, their are a lot. If you want some specifics email me at swtncdly@aol.com
99 01 991105 Year 2000 Readiness 9068 990113 Requesting Vehicle Security Codes 8703 971001 Climate Control System-Refrigerant 134a Use 29604 960711 Sulfur-Like Smell from Exhaust System 89602 960606 Use of Correct A/C Refrigerant 89501 951219 Retrofitting R12 A/C System to R134 49505 951214 Winter Tire and Wheel Summary WARR9512 950502 Pre-Owned Porsche - Limited Warranty Program 9504 950323 Paint Manual Supplements (WKD 482 620) TOOLS9502 950321 Quick Scope Plus 809501 950126 Automotive Refrigerant Identifier X9402 941227 Ordering VIN Plates, Certification and Emission Labels LIT9406 941117 Microfiche & Supplies, Update 2 19408 940830 Approved Anti-Freeze LIT9402 940719 Technical Information Books LIT9410 940505 Minimum Literature Inventory LIT9406 940329 Microfiche & Supplies 69403 940324 Mixing Windshield Cement LIT9404 940127 Workshop Repair - Manuals 09401 940125 Approximate Fluid Capacities-All Models From 1985 LIT9402 940111 Technical Information Books, Update 1 LIT9401 940106 Technical Specification Books, Update 49314 931221 Tire Manufacturer Contacts 99310 931221 Wiper Motor Cover 49303 930928 17 Inch Approved Wheels & Tires TOOLS9303 930921 Diagnostic Testers 19305 930921 Cooling Fan Motor 99308 930914 Discharged Battery/Alarm System Malfunction 59302 930812 Water Entry Into Rear Hatch Area (Coupe Only) 49310 930805 Brake Vibration Damper - New Application Information EQUIP9303 930729 Auto Scopemeter & Engine Analyzer 49308 930518 Power Steering Gear - Diagnosis 49305 930415 Installation of 18 Inch Wheels Not Approved By Porsche 49305 930323 18 Inch Wheels Not Approved 99303 930318 Correct Wiper Blade Application 09301 930218 Centering Adapters For Stationary Wheel Balancers 49303 930119 17 Inch Approved Wheels and Tires 49302 930119 Winter Tire/Snow Chain Summary 89208 921222 A/C Oil Filling Capacities 89205 921203 New Sealing O-Rings For A/C System 49205 921203 Groaning Noise From Front Brakes. 9201 921119 Technical Information Books 19209 921103 Cylinder Head Gaskets and Machining Cylinder Heads 69205 921103 Noise When Turning Steering Wheel All W/ Air Bag Option 99203 920929 Poor Electrical Pin/Ground Lug Connections 29204 920929 Battery Discharging 69204 920903 Air Bag - Notification of Deployment & Precautions 19208 920804 Camshaft Drive Belt Noise LIT9201 920625 Techincal Information Booklets 19207 920417 Engine Oils That Minimize Carbon Build-Up LIT9205 920410 Supplements Workshop Manual (Wkd 482 520) 19206 920407 New Pistons and Piston Rings LIT9201 920403 Technical Information Booklets LIT9203 920403 Valid Service Bulletins 19204 920320 Toothed Engine Belts Handling WARR9210 920320 Tampering With Emission Control System 49203 920310 Brake Disc and Wheel Hub Run-Out X9201 920204 Purchasing VIN Plates, Certification and Emission Labels LIT9104 911220 Workshop Repair Manuals 49104 911122 Summer Tire/Wheel Rim Summary 49101 911122 Winter Tire/Wheel Rim Summary ATRATB078 911101 How To Use A Pressure Gauge - Automatic Trans. LIT9101 911008 Technical Specification Books LIT9109 910823 Literature Inventory Minimum Requirement 69105 910816 Air Bag Scheduled Maintenance 19110 910730 Coolant Pump Leak Diagnosing 99104 910730 Porsche Radios and CD Players Requiring Security Codes 29102 910614 Spark Plug Threads Should Be Clean and DRY 49105 910517 Repairing Horn Buttons On Air Bag Vehicles 89102 910517 Substitutes For R-12 Refrigerant 19105 910517 Oil In the Cooling System 19104 910326 Valve Seal Replacement TOOLS9103 910322 Porsche Special Tools TOOLS9102 910322 Rebuilt and Exchange Program For 9201 and 9268 Tools WARR9102 910312 Microfiche Tips, Actual Time Diagnosis Time TOOLS9101 910115 Modules For Bosch Tester 9288 X9101 910115 Purchasing VIN Plates, Certification and Emission Labels TRAIN9101 910115 Training Certification Expiration 49011 901214 Chrome Plating Aluminum Wheels 99005 901214 Alarm Conntact For the Radio LIT9004 901204 Technical Information Booklets Currently Available WARR9023 901204 Current Warranty Bulletins LIT9013 901119 Updated Maintenance Checklist Countermat 29009 901113 Prevent Gas Cap Lock From Being Used to Duplicate Ignition Key 19011 901113 New Type Engine Mount 89002 901030 Modified Air Regulation Controls 49005 901030 Application of Vibration Dampers and Damping Plates 49010 901009 New Brake Pad Material Application 29008 901009 Use of Non-Approved Microchips 29007 901009 CO Sample Pipe 19017 901009 Engine Oil Pressure Relief Valve Description 29006 901005 Spark Plug Interchangeability 69001 901002 Air Bag Notification of Deployment WARR9019 901002 Toe Check Convertible Top, & Mileage Interval Service Changed ATRATB028 901001 Engine Testing With A Vacuum Gauge - Auto Trans. 59002 900918 Wiper Motor Hole In the Rear Hatch Glass Changed 89018 900907 A/C Compressor Warranty 49006 900814 Power Steering Pump System Cleaning ATI080190 900801 Twenty-Third Supplement of the Advanced Technical Information 19014 900706 Engine Repairs Maintenance Follow-Up Service LIT9008 900629 Technical/Literature Subscription Service LIT9007 900629 Useful Guides For Technical Specification 49013 900629 Replacement Pumps Damaged Due to Foreign Material 19016 900629 Approved Camshaft Drive Belts LIT9006 900622 Supplements That Have Been Issued to Date 79002 900622 Leather Upholstery Reconditioning 99003 900622 Telephone Installation Instructions 69005 900608 New Airbag Impact Sensors WARR9012 900529 Defects From Modifications to Electrical System 19014 900508 Connecting Rod Nuts Supplied As Spare Parts Incorrectly Made 19012 900508 Droning Noise From Oil Pressure Relief Valve LIT9005 900504 Wkd 481 821 Manual Supplement EQUIP9001 900504 Celette Collision Repair Systems EQUIP9002 900504 Wheel Alignment Equipment 69003 900420 Aid In Repairing Water Leaks In the Trunk and Top Area WARR9009 900406 Special Colored Warranty Mailing Envelopes LIT9006 900406 Printing Cycle For Dealer Parts Submission Report 49004 900403 Latest Winter Tire and Wheel Rim Recommendations 29003 900330 Air Flow Sensor Bolts TOOLS9002 900320 Special Tools 9005 900320 Access Warranty Start Dates and Recall Inquiry TOOLS9003 900320 Compressor Seal Replacement 9004 900315 Roadside Assistance Rental Car Authorization 19003 900202 Scrapping of Sodium Filled Valves 19004 900202 Coolant Hose Mounting Clips Too Small ATRATB9002006 900201 Automatic Transmission Fluid LIT9003 900126 Currently Valid Literature Bulletins 19005 900126 Sealing of Oil Pan 98906 891215 Routing and Securing of Electrical Harnesses 38903 891215 Transmission Fluids - Specifications 18914 891215 Oil Cooler Return Hose May Chafe WARR8914 891212 K02 Recall Tips WARR8915 891212 Warranty Transactions, Close-Out LIT8918 891208 Vintage Tools 28908 891208 Cruise Control System 48910 891122 VR-Rated Summer Tires 38906 891020 Hydraulic Clutch - Air In System 48912 891020 Stabilizer Bar - Modification 48911 891020 Emergency Brake Shoe Retaining System 18913 891013 Engine Cooling Thermostat - Modification 48906 891006 Brake Squeak ATRATB8930 891001 Automatic Transmission Math Part 2 18907 890915 SST P200A - Adaptation For Oil Cooler Testing X8904 890901 Motor Vehicle Theft Law Enforcement ACT - Parts Marking ATRATB8927 890901 20 Steps To successful Auto Transmission Repair 88902 890901 Refrigerant Recovery/Recycling ATRATB8923 890801 Automatic Transmission Math Formulas 98903 890728 Alarm Contact Insulator On Radio 18910 890707 Timing Belt Cover - Ventilation System Change 48907 890630 Brake Calipers With Improved Piston Seals 28904 890519 Battery With Vent Hose 18905 890505 Motor Oils That Minimize Carbon Build-Up 58901 890421 Transport Hooks - Removal 48901 890421 Brake Pulling/Brake Caliper Sliding Lubricant 48905 890421 Power Steering Pressure Hose Routing 98902 890414 Glove Compartment Light Wire Routing LIT8903 890127 Maintenance Procedure Materials 18901 890113 Checking Camshaft Drive For Damage 78901 890113 Seat Heating Wiring Diagram Update WARR8901 890106 Revision of the Warranty Policy & Procedure Manual LIT8901 890102 Service and Parts Managers Directory WARR8819 881230 Warranty Parts Submission 48812 881230 Winter Tire/Wheel Rim Summary 48810 881118 Brake Pads Without Asbestos 08803 881104 Maintenance Requirements - M.Y. 1989 68807 881021 Windshield Sealing 48809 881021 New CV Joint Grease 68803 880610 Sun Roof - Modification ATRATB8754 870901 All Automatics - Front Bushing Wear ATRATB8748 870801 Metal Sealing Rings - Automatic Transmissions 18703 870306 Tightening Procedure For Cylinder Heads 18530 851206 Torquing the Cylinder Head |
Thanks for the list. So many of these look interesting I'll probably get a subscription after all and print all the TSBs in their entirety so I have them handy.
what is a tsb? technical service bulletin?
Techinal Service Bulletin -- that's correct. AllData has these TSBs listed by number and by car and you can click them to read the actual bulletins for your car. They also have the Safety Recalls too. Looking at the titles of the TSBs above, there are quite a few that I would be interested in finding out more about. If it saves me time and/or money in making a repair or even a modification, it should be worthwhile for just $20/year.
The recalls you can find them at http://www.nhtsa.dot.gov
Nevertheless, I have account with alldata and it has proven a good investment. Even with the workshop manuals for my 964 I find myself looking and finding information there. For my 951 I do not have the workshop manuals and is a beauty to be able to go online and find the information quickly. As always, help from sites like this one and rennlist always help in narrowing down the problems. |
Thanks for the link. I immediately see that all 951's built through June '88 are subject to a fuel line recall for that high pressure line between the fuel rail and the fuel pressure regulator. (Over 53,000 cars may be affected.) They replace the hose with a better one. I wonder what the build date of my 89 is? I'll check that tonight before all my time and money goes up in smoke...
| All times are GMT -8. The time now is 07:35 PM. |
