p-talk's Avatar
solid front sway bushings
I'm cleaning up a 25.5mm front sway bar for install on my '84 944, and considering using the Racer's Edge inner sway mounts. Any BTDT on these? My only concern would be they'd squeak
Racer's Edge -- Racer's Edge Front sway bar, inner bushings
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 04-18-2010, 04:52 PM
SLED GUITARIST
Dan Himan's Avatar
I am curious about that to. I would like to stiffen mine up alittle.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 04-23-2010, 04:09 PM
That Guy
Techno Duck's Avatar
I have about 10k miles on my set, no noise at all.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-23-2010, 04:19 PM
p-talk's Avatar
Awesome, thanks Duck!
FYI, I emailed Racer's Edge about these bushings, and this was their response:
"You could use a lubricant on them should you desire but generally I don't think they squeak."
But they race, and probably don't really care about squeaks . But since someone's running them w/out noise, I think I'm going to run them. Guess I gotta finish "de-rusting" and painting that 25.5 bar now!
Old 04-23-2010, 04:28 PM
smokin_944's Avatar
You could also install a front sway bar bracket support to stiffen the overall feel of the car. This is a cheap but effective upgrade IMO.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 04-26-2010, 09:06 AM
p-talk's Avatar
Good call. I've got a set of these too, they'll be going in when the 25.5 bar does.
Old 04-26-2010, 09:47 AM
Will program for food
ghnat's Avatar
I also have delrin on my front and rears. No squeak from them. The front a-arm and spring plates are another issue. Squeak a lot in the cold, not so much in the heat.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 04-26-2010, 03:11 PM
