Mountain Road Maniac
ColoradoSteve's Avatar
Electrical issue
Just got the '83 up and running after a long, cold winter. Replaced the battery, it was not holding a charge. Here's the problem: the alternator ( about a year old) produces a steady 12.1 -12.8 v until I turn on the headlights, then my voltage immediately drops to 11, doesn't go any lower. It will do this if I turn on the foglamps or the headlights or both. Doesn't do it just for the parking lights. I have checked the headlight switch ( also new ) and the belt tension on the alternator and these are fine. I guess my next move is to clean all the contacts to the lights, anyone have any ideas what's wrong?
'83 944
'87 951- SOLD!
Old 04-28-2010, 09:17 AM
Voltage doesn't run anything, watts do. Your alternator shows correct voltage at a lower load if the regulator in it is working, but that is all a volt test does. If your windings are bad you will not produce enough watts to meet the draw everything in the car requires. You need to check that you are producing x watts at y RPM's, but I don't have the exact numbers for the car. Hopefully somebody else puts them out there.
Voltage = water pressure, Wattage = the amount of water coming out of the pipe.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-28-2010, 09:54 AM
the issue could also be the grounding cable. make sure it has a good solid connection to the body metal. take off the bolt and wire brush it clean to remove any corrossion/funkiness
Old 04-28-2010, 11:17 AM
Check the bushings in the Alternator the one in 8.5 N/A was incredibly worn, replaced it and it was all ok again.
Old 04-28-2010, 12:34 PM
With the car running in idle all loads off, 12.8 V is too low. You should get at least 13.5V with no load. With load, it should drop to 13V. Your alternator is not working. Have your aternator tested at a nearby auto parts store.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 04-28-2010, 02:09 PM
AKCJ's Avatar
I agree with bazar - below 13 is too low if the vehicle is running. The brushes (not bushings) in the alt are probably worn out. You can just put in new brushes for cheap or do a better rebuild like clean it up and put in new bearings while you're at it. Or, pop for a new alt.
I would also guess that there's a good chance the battery is toast from not being charged.
Tip - think of the battery as full at 13.5 volts and dead at 10.5 volts.
Red 83 944
Old 04-28-2010, 02:54 PM
Thanks for the replies , guys. I checked all connections and everything seems fine. I will have the alternator tested , I thought it was OK because I replaced the thing less than 5k ago. Weird.
'83 944
'87 951- SOLD!
Old 04-28-2010, 04:30 PM
