oil pressure release valve
I am changing the oil cooler gasket on a 85.5n/a 944, and am having a problem removing the oil pressure release valve nut on the housing, is it a left hand thread nut? I have try ed penetrating oil and heat,Its jammed.HELP
Old 04-28-2010, 08:44 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
NOT LH thread
Have done the job several times. It is NOT a left handed thread. I have a wrench that I ground down from the next smallest SAE size as they can be a bbeeatch. If you have the room a deep socket (6 pt) may also be an option. Heat with a propane torch and quench with pen fluid a few times and then shock or wake the thing (gently) by tapping on it. If that still doesn't get her out. Remove the EX manifold and take the OPRV out with the housing and deal with it on a bench where you can give it SPECIAL attention. (price and locate replacement housing in case there are casualties)
Get the best 6 pt box or open end as securely on there as you can and tap on the end with a hammer to twist it out usually works. YMMV.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 04-28-2010, 09:11 AM
Back from Beyond
^+1
When they freeze up they freeze up badly. I agree about removing the whole housing. Then take it to someone else and make it their problem.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 04-28-2010, 12:10 PM
Redline Racer
HondaDustR's Avatar
A 1/2" drive ratchet will work with the right extensions, especially with a long flex head breaker bar IIRC.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 04-28-2010, 12:17 PM
I got that sucker out.I used some p/bblaster and some heat then used a impact gun with 17mm socket came right out.The install of the houseing was cake, after that little problem.I followed clarks garage link on the oil cooler setup.Thank for your help.
Old 04-28-2010, 02:04 PM
