smokin_944's Avatar
Series 1 speedo cable set-up
WTF? I wanted to change the brake shields on my early car, and I had a hell of a time getting the grease cap off the rotor... the speedo calibration guy that worked on my car a year ago had to do some tinkering to make it work right. I wish I woulda run instead of stayin at his shop when I heard that. He ran the speedo cable through the grease cap and siliconed in place. Anyone got pics of the correct setup for the speedo cable on an early car? I have to fix the mess to move on...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 05-08-2010, 12:25 PM
That Guy
Techno Duck's Avatar
Its supposed to run through the grease cap, it is normally held in place by an e-clip however.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-08-2010, 01:44 PM
smokin_944's Avatar
The mech that worked on the car must have broken the clip because he used wire and some kind of hardened red silicone compound to hold it in place. I couldn't even see the tip of the cable til I stripped all the red stuff off. Cleaning the mess, 35 minutes, total job 1 hour... Plus the time it took to find an e clip the right size. All is right again...
Old 05-09-2010, 04:30 AM
