AXQ 4.2 Audi V8
I've heard it said that Audi used the same bellhousing pattern on their newer V8's as they did their 5 Cylinder engines, also the same as the 924 bellhousing pattern.
am I correct in this? I've got oppertunity to buy a 4.2 V8 from a tourareg (same as the audi mill) for a song and wondiering if I can piece together a hybrid drive train for another project (not going into a Porsche, but 924/944 drivetrain is what I'm hoping will work)
a few pics of my project |
nobody know?
Audi 5 cylinder was the same bolt pattern as the 924 2.0 motor, basically. But that was a LONG time ago - I wouldn't assume the newer Audi V8s to be of the same pattern. I'd check over on Motorgeek.com, or call 034 Motorsports - they'd know for sure.
1984 Porsche 944 - Mathilda the needy 2014 Audi Allroad - daily driver |
Audifans may also know. I know V8s have been installed in 5cyl cars but do not know what was done.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
What I've heard is that the tranny in the back of our 944s is the same tranny as used in the front of some Audi - probably the old 5000 - way back when. So the bolt pattern that would bolt up to an Audi engine is the bolt pattern on the front of the tranny. Because if you think about it why would the 944 tranny have such a wide bolt pattern just to bolt up to a torque tube? It's because the clutch was there and the engine in a front wheel drive car.
Andy D. Currently driving 2005 Audi A4 Currently driving 2006 Ram 1500 sometimes |
[ideola batman signal] this is covered well in the 924board forums.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
