-   -   Charging system confusion! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/540959-charging-system-confusion.html)
Arizona_928 05-05-2010 07:00 PM
I have been having what i believe to be alternator failure on my 85'. The first time i noticed it was on the way home from the drive-ins, and the battery light was slightly glowing. I popped in a spare voltage regulator and got 13.8V at the battery and that lasted for acouple weeks until i got a rebuilt in. The rebuilt only put out 12.8V but didn't triger the light until acouple weeks later. I finally got fed up with replacing them, and went to checkers and bought one of theirs. The first one they gave me was bad out of the box so I had wait till today to get it in. They put it on there machine and it passed, however at the battery I'm gettting a reading of 12.2 volts. battery is brand new of today, and checked out good just now.. I'm leaning towards another bad alternator, but could bad wiring also be a cause?
AA_Ezra 05-05-2010 11:29 PM
New bat should be above 12 volt so that is good. Sometimes the battery light goes on simply because the conection to the small wire from apt to dash is dirty and yer apt may be just fine. Well of never hurts to clean comtact points. Clean the power wires that go from alternator down to the starter under the car. Make sure battery ground surface to chasis is clean and clean the bellhousing to chasis ground wich is behind the intake mani. Bad ground is all it is hopefully wich could the culprit
Arizona_928 05-06-2010 04:54 PM
I don't have a ground to bell housing. One of the PO's tricks when he messed up on the clutch.
I'm also having some running and starting problems with car. I can go around the block then come back home shut her down and it will fail to restart like the car is just running off of the battery.
AA_Ezra 05-07-2010 10:53 PM
Battery to start and apt to keep it tuning. Well if your missing it create one. The block has got to have one to the chasis. What is the output on the alternator post? Did u clean the wires on the starter b/c they go there first before charging battery
Arizona_928 07-12-2010 05:54 PM
Woa long bump. I have replaced the grounds with some 00 welding wire, and cleaned all contacts at the starter, battery, and alternator. After I replaced the ground and moved up to a military style battery connectors I was getting 13.8V, then went for a short drive and on the way home it dropped back to 12.2V.
I'm getting 10V at the alternator post. I think my new alternator is bad again.
fmartenies 07-12-2010 06:04 PM
4 bad alternators in a row? That doesn't sound reasonable. All the alternator does is spin and generate electricity to put back into your battery via regulator/rectifier.
I can't tell from your post, is it a new battery? If so check everything inline from the battery to the alternator. Make sure nothing is grounded there or otherwise "custom" or all your charge might not be making it to the battery.
Arizona_928 07-12-2010 06:20 PM
Battery is a month old. My old one failed again. Yepp I've been through 4 alternators and 3 batteries.. ha! I've checked all of the wiring, and even converted the Positive side terminal to a lug style, shrink wrapped and the whole 9 yards. I can replace a alternator in around hour now..... =D
I take it 10V at the alternator is bad?
fmartenies 07-12-2010 06:29 PM
Are you sure the wackjob wiring isn't draining the battery, and the majority of those alternators just couldn't keep up? I'll concede 1 or 2 may have been bad ;-)
Arizona_928 07-12-2010 07:04 PM
haha. I'm building a new harness now, and will get that alternator tested for the hell of it. I've replaced the original harness with a really good used one from 20th street auto. idk the wiring isn't corroded or anything it just seems that it's the most likely cause.
John_AZ 07-13-2010 06:57 AM
Levi,
Compliments on the "00" ground wire and military style connectors.
Some members run the 12V wire from the alternator directly to the battery. This will bypass the starter lug connection.
Hook a new HD ground from the alternator to the block. Yes I know it is mounted directly.
Replace the tiny, thin wire from the alternator to the idiot light. Sometimes the wire is old. frayed, or the connection is bad. If this wire is bad, you will get poor charging.
Instead of the crappy 90 amp OEM Checker/O'Reilly alternator--, go online-eBay and see if Eagle Electric has a 115 amp upgrade rebuild with no core charge available for your car. Or any reputable rebuilder.
The 115 amp will help your car with old-resistance high, wires, old fuel pump that takes more amps and other things that need help.
GL
John
Arizona_928 07-13-2010 10:26 AM
GL
John
That's a good idea. I might run some 1 or 0 welding wire just to over do it.;)
the tiny wire is the blue wire?
John_AZ 07-13-2010 10:39 AM
Yes, blue, blueish, greenish/blue anything close.
I have used a domestic car long red battery cable-----thinner than 1 or 0 stock & easier to work around the intake and firewall.
John
AA_Ezra 07-13-2010 01:06 PM
4 guage worked for me I used 1-2 amps kits from tsunami, Marine grade stuff so the copper wire was tinned (every single strand) to help with corosion.
Battery has 2 grounds (shorter the better) Alternator to starter, to battery all 4 guage.
Rebuilt alternator about 2-3 years old and the key
an ADJUSTABLE Voltage regulator running at 14 volts or so
John_az
How dose the 12 guage wire or so for the idiot light create poor charging if its damaged. I thought it's only purpose was just to alert you of alternator failure
Az_porschekid
Are you getting the alternators all from the same place ( bad batch comes to mind)
Back in the day when Iceshark was around (good info look him up) he mentioned that there was a batch of adjustable voltage regulators that went bad ( voltage up and down) it's possible that you got a batch of alternators that had a bad batch of voltage regulators
it's only about 20$ or so for a new one and it might be worth checking out
Maybe the alternator belt is too tight?
John_AZ 07-13-2010 03:18 PM
Jaime O.
In this thread, post 5 it is explained.
If the wire is damaged, cracked or shorting or bulb burned out it will affect the charging system on early cars
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/445598-battery-dying-need-help-quick.html
Levi,
Have you checked for battery drain (current draw) when the car is off? Should read about 10ma. Here is a pic of mine.
http://forums.pelicanparts.com/uploa...1279062953.jpg
John
AA_Ezra 07-14-2010 10:43 AM
OK well that makes a little more sense . So in other words if the bulb is out or the wire it grounding (shorting) some place then it creating a draw/leak of power
Arizona_928 08-01-2010 01:20 PM
went to get the alternator tested. it's bad.... It's probably the voltage regulator. I found Daves Volvo Page, and he stocks a internal and external voltage regulator.
I did a current draw and I'm not sure if i'm doing it right, but i'm not getting anything on my multi-meter. The Battery light is still on with the car running...
I know John you've been trying to get me to buy one of those eagle electric ones forever now. I just feel guilty for spending 250$ on these Hecho en mexico junk, and not being able to use it.
Edit: How well do you think a 944 could hold up with a 175 amp?
http://cgi.ebay.com/ebaymotors/Porsche-924-944-Bosch-Alternator-175-Amp-1983-1988-/350320921075?cmd=ViewItem&pt=Motors_Car_Truck_Part s_Accessories&hash=item5190c109f3
John_AZ 08-01-2010 03:38 PM
Fast Daves Volvo Page ;)
Hook your MM up like I have mine. Disconnect POS+ cable. Clamp red wire of MM to batt + post------------Clamp black MM wire to POS+ battery cable end. Set the MM to read DC amps-----start at 200ma setting. I have mine set at 20ma
$250! Did you get a bottle of premium Tequilla with it?
Porsche 924 944 Bosch Alternator 175 Amp 1983-1988 : eBay Motors (item 350320921075 end time Aug-22-10 17:42:14 PDT)
Answer:
High Output Alternator
OR
Starting & Charging System Troubleshooting
GL
John
AA_Ezra 08-01-2010 03:39 PM
150$ is a great pei e bit 185 amps. I duno about that one. I would ask them to prove it or atleast ask what rpm it hits 175. Damm local alf rebuilder pretty much avoided cranki. Mine up as if it was imlosible
AA_Ezra 08-01-2010 03:40 PM
If u want to just buy a good voltage red let me know. It's adjustable, inexpensive and has worked for about almost 5 years
Arizona_928 08-01-2010 08:05 PM
Whoa. I just exchanged the alternator with another one from checkers. The one they gave me had been dropped, and had a couple studs bent. I took it and on the way home I stopped by the checkers by my house. They know me as the kid with the porsche.. lol anyways they recommended that I take it back and get the one I turned in as they won't warranty a dropped alternator. After messing around with the manager from that store I somehow talked my way into getting my money back and the alternator that was dropped returned as my core! Needless to say I feel like I robbed the place.
Here's the alternator. Also It just tested good over at autozone.:D
http://forums.pelicanparts.com/uploa...1280721842.jpg
