I recently purchased a 1983 Porsche 944, 5 speed.
There is a vibration around 1200 rpm so I looked around at the engine. The lower pulley that runs the alternator and air conditioner, the one attached to the crank looked out of round. I purchased another off of ebay, replaced it… checked it and it’s a little better but still looks out of round when running and the vibration is still there around 1200 rpm. Did I install it incorrectly? If I remove it and look at the outer balance belt drive that it mounts to at idle it looks fine, not out of round. I see there are balance weights on the pulley… is there a trick to how it’s mounted? Thanks in advance for any advise... Robert
1983 Porshe 944 N/A 5sp Guards Red |
I've looked at the passenger side motor mount.. it looks fine but then I don't really know what to look for. I do see the serpentine pully wobble...
Custom User Title
Is the crank bolt torqued properly? (? 150-155 FtLbs?). Nothing inbetween the pullies and the gears?
When you had the pully off, if you laid it on a flat surface was it flat or warped? If the pully was decently flat and not out of round, I'd think either there was something inbetween the pullies/gears that was preventing it from sucking all the way in flat, or that the assembly wasn't properly torqued. If the pully was not flat, I'd buy a new (used) one.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Toofah King Bad
Yeah, that is weird. Bent crank (very unlikely) or install problem. I wonder if the bolt is bent? Woodruff key deformed? I needed to do some filing on the first couple I ever took out - DOH!
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
the pulley appears to be out of round.
I used a caliper on the old one and it looked like it's out of round by .015 here is a terrific link for 944 motor mounts. I guess I will try this before I do anything else with the balance belt. Motor Mounts is removing all the other things really necessary for the motor mount change?????
1983 Porshe 944 N/A 5sp Guards Red Last edited by rrwebster; 05-16-2010 at 04:41 AM.. |
