Porsche Crest Mookeeh camber plates
Someone please take a look at these pics of the driver's side and ensure me that I have installed these correctly?
There is nothing between the top of the spring plate and the adjustable camber plate?
The movement of the camber plate is towards the outside of the car
1980 ROW SC
1986 944
looking for a 914
2008 4 Door Wrangler
Old 06-02-2010, 08:01 PM
drift a 944's Avatar
Appears to be installed correctly... As long as the top part of the cone is just touching the monoball bearing thing and not the gold piece it should be ok. Either way, those Mookeeh camber plates are GARBAGE! Do a search for them here on Pelican or on Rennlist and I'm sure you will see the trouble people have been through with them. Let me guess, you are hearing lots of popping noises and can feel them in the steering?
My own experience with those gives me nightmares just thinking about it again.
- Elliott Grafton - 944Barn
Old 06-02-2010, 08:51 PM
Toofah King Bad
Rasta Monsta's Avatar
Don't track those things.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-02-2010, 08:55 PM
Just did the driver's side....haven't done passenger yet. Seems some folks on Rennlist are ok with them. just needed some economy....hope I didn't screw up.
1980 ROW SC
1986 944
looking for a 914
Old 06-02-2010, 08:57 PM
Porch's Avatar
I have them, and i've read about them on rennlist too. Only a few people have had problems with them. Mine are at 10k miles and still going great, as are quite a few other peoples.
Even if they were garbage, it doesn't change the fact that everyone else is ripping people off for them. I refuse to buy the more expensive ones on principle alone.
Edit: for example, the LR camber plates. They are the exact same design as the Mookeh's. Maybe--MAYBE--they have a better bearing in them. Do you think the bearings cost $300 more?
~Chris
1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear
1993 Jeep Cherokee - 3" Lift, 30" tires
Old 06-03-2010, 08:15 AM
Looks right. I have these on my SPEC 944 racer and not a problem.
Old 06-03-2010, 08:24 AM
Well not everyone has had problems, but when a simple search yields so many problems and negative experiences, I would be skeptical of buying a product like that. Unfortunately for me I bought mine when they were first introduced to the market and I did not find any reviews.
Here are some examples. Just sayin'.
Ground Control camber plates vs. Moooookeh. - Rennlist Discussion Forums
Mookeh Camber Plates binding! A MUST READ! - Rennlist Discussion Forums
MOOKEEH MK1 Camber Plates - Rennlist Discussion Forums
Old 06-03-2010, 04:17 PM
Toofah King Bad
Well, hate to point out the obvious, but this is a critical system, and you should really think twice before experimenting with a cheap component. If it fails on the track, you could lose the whole car. Is that worth a couple hundred dollar swing?
Old 06-03-2010, 04:19 PM
So ideas as to how to set the camber on them? Use the eccentric bolt still?
1980 ROW SC
1986 944
looking for a 914
Old 06-04-2010, 03:30 PM
