Zombie
Front Crank Bolt Removal with No Flywheel to Lock?
My 85.5 engine is on a stand - with clutch and flywheel removed so I could use the bell housing holes to secure the engine to the stand.
So...with the clutch and flywheel removed - any suggestions as to how I could lock the crank if I want to remove the front crank bolt? Thanks!
Old 05-15-2010, 03:57 AM
Not recomending this but, in the past, I have just put a breaker bar on the bolt and braced it on the ground or what ever and cranked the motor over (coil disconnected of course). Starter motors are torquey haha. Must make sure its in the correct direction to loosen the nut/bolt.
Not sure how it would work on a 944 but when your half cut and need to change a timing belt on a 4 runner it works well.
-1986 944 NA
Old 05-15-2010, 04:35 AM
If the engine is on a stand, impact wrench is what you need.
If you don't have that, put two of the flywheel bolts to the back of the crank, and use a pipe or a steel bar to counter while you loosen the front crank bolt.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-15-2010, 05:45 AM
Proprietoristicly Refined
John_AZ's Avatar
....rubbing my eyes....
I keep seeing double posts
Put the engine on the floor (again) and replace the flywheel and bell housing.
Lock the flywheel----be very careful you do not chip the flywheel teeth----with a steel shaft.
Get out your air impact wrench.
EDIT---try bazar01 idea first
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-15-2010, 05:46 AM
Originally Posted by bazar01 View Post
If the engine is on a stand, a good Ingersoll-Rand impact wrench is what you need.
There, I fixed that for you!
Good luck, George Beuselinck
Old 05-15-2010, 06:00 AM
Just a note... We had HELL getting my bolt out. Thats with Good IR impacts. We were looking at how to get the Hyrdraulic impact in there but it was too big. Ended up using a the 4ft ratchet part of our 6ft snap on torque wrench.... That baby was TIGHT
Old 05-15-2010, 06:18 AM
unindicted co-conspirator
looneybin's Avatar
just thread a bolt into the spark plug hole, then when the piston hits up against it, you can go ahead & wrench on that pesky crank bolt
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 05-15-2010, 07:53 PM
"Dude! You kicked my car.
Rudeboy42's Avatar
go with the impact gun idea that's what I used work perfectly the first try.
Old 05-15-2010, 08:01 PM
Used & Abused
Hydrolock the pistons! Pour oil in all the cylinders and replace the spark plugs. One of them should hold compression
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 05-15-2010, 08:40 PM
George.... He typed in Green.... AKA Sarcasm.....
Old 05-16-2010, 10:23 AM
cover a 2x4 in a plastic bag and slide it between the crank and the inside wall of the block.
Old 05-16-2010, 10:45 AM
Redline Racer
HondaDustR's Avatar
ooohh...I like the oil idea! Clever thinking. That and a 3 ft breaker bar would probably do it.
You could also bolt the flywheel back up temporarily with the engine off the stand, install the bellhousing and use a flywheel lock if you have one. I think I just installed the flywheel and slid a long bolt through one of the holes just inside the step in the flywheel where the pressure plate bolts to so the bolt jams against the raised reiforcing castings around the RMS area when you turn the crank. It held good enough but probably isn't the best idea, as the block material is a bit brittle.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-16-2010, 07:09 PM
