Marko911/944's Avatar
Undercarrige damage
I'm back to work on the 88' 944 curb surfer. The shocks and struts came this week, so i'm ready to tear into it Sunday. One problem is I loaned (joke) my spring compressor's to my boss, and never got them back. I guess i'm renting some. Anyway, anybody have advice or tips on making the strut install easy? Tech info? I also need to adjust caster/ camber and alignment. Thanks.
Old 05-15-2010, 11:03 AM
Proprietoristicly Refined
John_AZ's Avatar
You could go to HarborFreight and get a spring compressor and send the bill to accounts payable -$9.99
After doing it multiple times on my cars, I do not use the spring compressor. It may be different on the '88 944. There is spring tension but I am able to compress the front springs and get the top on. Caution-dangerous
Now on the alignment.
When you remove front struts ----mark the strut on the steering knuckle with a can of white paint and a steel scribe first before you take them off.
Here are a couple of DIY home alignment posts that will get you close enough to get to a shop.
EDIT: This is the one I use from the Tech Section above ^^:
http://www.pelicanparts.com/techarticles/home_toe_in/home_toe_in.htm
Wheel Alignment A Short Course
Modification Notes
For your truck..
Everything Auto: DIY Wheel Alignment
DIY 4 Wheel Alignment
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Last edited by John_AZ; 05-18-2010 at 05:38 AM.. Reason: should be "accounts payable"
Old 05-15-2010, 11:22 AM
Thanks, John!
That helps, not the accounts rec part, but the paint and scribe bit. Carefree highway huh? I used to tear up the desert out that way pretty good back in the 80's. Now I tread lightly here in Colorado. Thanks again.
Old 05-18-2010, 05:32 AM
