88 front suspension question
My sons 88 is in decent driver shape but need to do at the very least the front inserts. What is the preferred method to replace as a complete assembly or just replace the inserts while still in the car if that is even possible? I am use to 911 and 914 front suspension so assuming because of the springs you have to remove as an assembly?
The second part of this is what is the best bang for the buck for a broke college student? Should used even be an option?
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
In the Fires of Hell.....
Koni hacksaw conversion or strut replacement are your only options.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
944 S2
I would shop around. I have a 91 and looking to do stock replacement currently priced round $270 per strut
