replacement fuel lines
Time to replace the fuel lines from the rail over the headers.
Has anybody used the Rennbay lines? Opinions?
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 04-17-2010, 07:48 PM
Arizona_928's Avatar
I sent travis a e-mail awhile back asking what the difference was between the two. The deluxe Kit is basically the lindsey kit, but uses rubber hoses instead of stainless steel.
The basic is the rubber hose, but you instal them where the originals were, so you don't have cut your hard fuel lines like the lindsey or deluxe sets. plus the basic comes in blue.
I have the blue ones, but haven't installed them yet.
dolor et pavor
Copyright
Old 04-17-2010, 08:34 PM
Thanks Levi,
I'm leaning towards the basic set. I don't really trust compression fittings on the fuel system. Prefer the flare nut instead!.
Bruce
Bruce P.
Old 04-17-2010, 08:45 PM
I believe eagleday sells one as well
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Jamie,
thanks for the eagleday info. looks like the same as Rennbay
Bruce P.
Old 04-17-2010, 09:17 PM
I think they get theirs from rennbay...
dolor et pavor
Copyright
Old 04-17-2010, 09:28 PM
choinga's Avatar
I used the braided lines from Lindsey Racing - and they have the insulation as well - love them. They have worked well for me (had them installed for over a year). Hardest part is getting the damn plastic piece out of the inside of the wheel well...
Here's the link: 944 / 951 BRAIDED REPLACEMENT FUEL LINES at LINDSEY RACING - Your Porsche Performance Parts Center
Here's Lindsey's write up on their lines: FUEL LINES at LINDSEY RACING - Your Porsche Performance Parts Center
Old 04-17-2010, 10:00 PM
Roman944's Avatar
lucky bastards with late cars, LOL
FYI, I talked to Dave about a week ago and he said that there will be a EARLY fuel line kit coming in next few weeks
but I'm going to do my lines as well, and I might go with a Rennbay kit - these guys are awesome, I've never had a bad deal with them!
Old 04-18-2010, 05:04 AM
i have the rennbay deluxe kit on my early N/A, works great and the compression fittings aren't anything to worry about there isn't that much pressure going through the fuel lines.
1983 944 Guards Red (87' Implant Complete)
Old 04-18-2010, 11:44 AM
Proprietoristicly Refined
John_AZ's Avatar
Pelican member Pauerman has a web site:
Fuel Lines
Arnnworx gives good information:
Fuel Lines
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-18-2010, 05:23 PM
John,
Thanks for the links. Bruce did a nice writeup.
I was leaning towards the ss braided lines. Somewhere, I was reading about heat being an issue with the braided lines making them less desirable than the insulated rubber like the original lines
Bruce P.
Old 04-18-2010, 06:40 PM
BoxsterGT's Avatar
Porsche Crest
I offer a Fuel Hose Fix as below...........
With this you cut & flare the fuel tube in behind the Rt Front shock abs.
Shown with a Mini Tube Cutter where you must cut the original tube. You then slide the Metric flare nut (provided) over the tube, flare it & connect the hose.
Takes about an hour to do the job.
This is also available in Metric Braided Zinc or Braided SS.
Please, no PMs. My box is always full.
email me for info.
Len at Autosportengineering dot com
Old 06-01-2010, 03:07 PM
