Tidybuoy's Avatar
Holy Crap Batman! Shredded Flex Damper Photos
Wow! & Unbelievable, comes to mind. I've been working on replacing my Flex Damper and I got the Torque Tube moved tonight so I can access the Flex Damper.
Here's some photos. It truely is Hump Day as I am exactly 1/2 Finished!
Old Flex Damper - Still on the Car. Torque Tube Dropped & Out of the Way:
What's Left - Outer Section Just Fell Right Out
Notice the little metal ears, that's what got me home as they were clacking
against a matching set on the auto-flywheel:
Old vs. New - Front Side:
Old vs New - Back Side:
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 06-02-2010, 09:15 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Your installing a new rubber center instead of a spring center?
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 06-02-2010, 10:48 PM
Tidybuoy's Avatar
Yes, this the a flex damper for an automatic transmission.
Vern
Old 06-02-2010, 10:55 PM
flash968's Avatar
if only they made a beefed up version of that - the 968 tip has the same dumb thing - they age out and shred just like yours
Old 06-03-2010, 04:11 AM
All Spooled Up
That's exactly what happened, way-back-when, on my (lightly powered) 77 924 automatic. I think that setup (rubber flex-plate) was one of porsches worst ideas.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 06-03-2010, 05:27 AM
Tidybuoy's Avatar
Well, now that I've been thru the process....I'm going to be on the hunt for a manual trans and all the necessary parts to convert. I'm kicking myself because when this happened, I saw an '88 with a broken timing belt for $2k on Craigs List (only 70 or 80k miles & local).
Anyway, now that I've seen how it's done, it's really not that bad....just a little time consuming.
Vern
Old 06-03-2010, 08:27 AM
your average wrencher...
some of the older street bikes, like GS 1000 had a hard rubber rear sprocket for a "smoother" ride. they do shred when you dump the clutch though.........
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 06-03-2010, 10:22 AM
Yah, I think you can put a spring center clutch in place of that damper. Problem solved.
Old 06-03-2010, 04:54 PM
flash968's Avatar
if only - i'd love to see it though
Old 06-03-2010, 08:57 PM
Tidybuoy's Avatar
In the next year, I'm going to acquire all the parts that I need to convert to a manual trans. I love my car but I hate the fact it's an automatic. After doing this job, I can see that converting will not be too difficult.
Vern
Old 06-03-2010, 11:28 PM
...I follow with high interest your posts, thanks for pics...they will be useful to me...
Don't understand why, after all this job, you want to convert to manual!?
Old 06-04-2010, 05:18 AM
Manual is better And as to why he decided after the job,... who cares Manual is better
Old 06-04-2010, 05:49 AM
Tidybuoy's Avatar
I want a manual for the fun-to-drive factor. Yes, it may be a waste of money after doing this job but it is the "doing" of this job that has taught me that it's not that difficult to do.
Keep in mind, when I say a year, it will probably be three . Shall I post pictures of some of my other unfinished peojects...
Vern
Old 06-04-2010, 08:12 AM
Hmmm. Too bad you can't get a Trojan damper. They seem to know about rubber...
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 06-04-2010, 08:23 AM
unindicted co-conspirator
looneybin's Avatar
it could even have ribs for "her" pleasure
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control
'86 944 - Wilks PP2, strut brace, harness bar, M030 sway bars, 200# springs, koni adj, throttle cam, K&N filters, momo wheel & shift knob - faster in the twisties than a mustang
Old 06-04-2010, 09:36 AM
If she's the driver...
Old 06-04-2010, 09:40 AM
looneybin's Avatar
"she" is the car - it IS an automatic afterall, just kidding Vern
Old 06-04-2010, 10:12 AM
Schumi's Avatar
I looked at those pictures and honestly did not know what I was looking at.
I've never seen nor worked on an automatic 944. And I never want to.
M
Old 06-04-2010, 10:50 AM
If anyone else on here needs to replace there damper just put a used 944 spring center clutch in its place. Lots more affordable.
Old 06-04-2010, 02:18 PM
flash968's Avatar
i sure wish that worked on the 968 - unfortunately the things don't fit
Old 06-04-2010, 02:28 PM
