mikeran's Avatar
badly rusted bolt removal help
I removed my exhaust system. to get the 2 sections apart I had to cut the bolts. Now it seems the main bolts are rusted into the flange on the cat section.
Any suggestions on what or how I can get them out so I can reuse this section?
I tried heating them, pounding on them, PBing them nothing seems to work.
87 944 - Daily Driver - Son took it and now brought it back
Old 03-04-2011, 02:16 AM
yarfk
kfray's Avatar
Heat them until they are cherry red and then use a bigger hammer.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 03-04-2011, 02:51 AM
Endat's Avatar
angle grinder? hacksaw?
pics?
Old 03-04-2011, 03:07 AM
choinga's Avatar
could always drill them out and re-tap or helicoil...
1987 951 - SFR 3" exhaust, Vitesse MAF w/ 83# injectors, Vitesse S2R Turbo, Tial 38mm, Lindsey MBC, Spec Clutch w/ Fidanza flywheel, Turbo S Brake Kit w/ Drilled Rotors, Koni shocks, 17" Michelin PS2's on Fikse FM5's, Saratoga Sunroof.
Old 03-04-2011, 05:42 AM
mikeran's Avatar
Well I only had a plumbers torch and it can't get them hot enough so I gave up after a while and took it to my local muffler shop where they had a bigger torch and once heated hot enough they could pound them out with a hammer and chisel.
Thanks for the suggestions
Old 03-04-2011, 08:06 AM
Redline Racer
HondaDustR's Avatar
Yep. Plumber's torch that can burn MAPP gas was one of the best tools I ever bought. Lots hotter than propane.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-04-2011, 11:39 AM
I would try a can of coke. If not that then Auto Trans Fluid + laquer thinner. 50/50 mix. Let it sit for a while.
Old 03-04-2011, 11:50 AM
