Captain Carerra
Send a message via AIM to N.A.S Story
trying to figure out what this is...
Back for a little more help to ease my mind. realized this had like a vac line attached to it but was broken off. can anyone tell me what this thing is/ does and if its important.
Old 06-07-2010, 07:47 PM
winter-hater club member
nynor's Avatar
vacuum canister. it stores vacuum, i believe, not sure exactly how necessary it is.
get a pen with the metal ink cartridge. cut the barrel off at the tip and about an inch below. epoxy the narrow end into the broken port. the vacuum line should reattach with a rubber boot. clean the ink out, of course, beforehand, with some rubbing alcohol.
"COOL PRIUS!" - Nobody Ever
Old 06-07-2010, 07:53 PM
That Guy
Techno Duck's Avatar
The tank is really only needed for when you use the HVAC controls.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-07-2010, 08:06 PM
nynor's Avatar
that makes sense.
Old 06-07-2010, 08:11 PM
Captain Carerra
sounds good to me!!!
thanks for the quick replies. pictures make everything that much easier. back to the garage it go.
Old 06-07-2010, 08:15 PM
ernie9944's Avatar
It does connect to the control valve (blue) coming out the brake booster follow the brown vac line.This is on an 83 your cannister is at a different location but do the same job.Techno Duck is rigth.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 06-09-2010, 02:20 PM
your average wrencher...
ernie9944, what kind of oil filter is that? or is it a cap?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 06-09-2010, 05:31 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Cap for Power Steering Reservoir.........the yellow one...???
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 06-09-2010, 05:56 PM
ernie9944's Avatar
This is a very very strong magnet sitting on top of the oil filter help keep all the microscopic debris out of your motor,had it for quiet a while it stick to the filter like glue & you got to really pull on it to remove it if you set it on a piece of steel forget it the darn thing act as if it's screw on there that how strong it is.
Old 06-09-2010, 06:28 PM
OOOOOOOOHHHH........ok. I was thinking "where did he find an oil filter that looks like a star?"
that's pretty cool though, and it even matches your paint scheme
1982 931 *project*
Old 06-09-2010, 07:06 PM
WOW!
Never seen such a clean under-hood!!
I wish I could have the same on mine!!
What kind of cables are installed for spark plugs? I would like to change mine too
Old 06-10-2010, 12:07 PM
ernie9944's Avatar
What kind of cables are installed for spark plugs? I would like to change mine too[/QUOTE]
Thank's for the nice comment indio76 yes I use to keep the car very clean all around had it 26 years but sold it last summer ____the Grey spark plugs wires are Bosch Silicone (OE) 7mm, the yellow one from the Coil to the Distributor is an Accel 8mm wire that I fabricated myself .
Old 06-10-2010, 01:03 PM
