-   -   Another no start.... Not the DME relay (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/547598-another-no-start-not-dme-relay.html)
porsche4life 06-11-2010 10:19 PM
So... My baby stranded me today... Cruising down the road and flat line.... Swapped the DME with one out of my silver car that should be good... Still nothing... What should I check next? I've got a spare fuel pump too....
zedsn 06-12-2010 05:07 AM
pull a spark plug and check for spark. Take off the end cap to fuel rail, put a hose in it and run hose to a bucket and crank the car over and see if you have a good amount of fuel flowing out. Clarks garage can give you specifics. If no spark could be a refernce sensor. My 83 na stoped running at a traffic light out of the blue and it turned out to be a refernce sensor. You can also unplug your sensor connectors and clean the ends and put back together and see if that makes a difference.
John_AZ 06-12-2010 05:22 AM
+1^^^
Wiggle the reference sensor connection on top of the rear engine. Clean it. Check for tach bounce when you grind the starter.
Fuel filter clogged.
Rotor loose
Battery cable ends falling apart.
Neg ground on bell housing.
Out of gas
Rodent chewed wires.
A few days ago a member posted he had drivetrain vibration-----after many members suggestions-----he posted back to say it was fingertight spark plugs and after he tightened them down the car ran perfect. Sorry, just a rant....still pounding my head on the pavement. SO=check the easy stuff first.
GL
John
porsche4life 06-12-2010 03:26 PM
Fuel filter is less than 10k old and I am very picky about gas... Cap and rotor are new.... Cables are good...
I'm hoping no rodents...
I'll check the sensors and for spark.
porsche4life 07-03-2010 12:16 AM
Cap and rotor.... Good...
Cables... Good....
Plugs... Good...
DME... Good...
Fuel pump.... Good...
Reference sensors... NEW...
Spark? Yes...
Fuel? I have fuel to the rail... After cranking the plugs are still dry.... Injector issue?
Also.... As soon as I turn on the key my cooling fans come on... Have I got something haywire in my electronics?
LUFTMAN 07-03-2010 03:00 PM
check airflow meter for sticking or binding
stogie25 07-03-2010 06:24 PM
Stupid question, but have you checked all your fuses?
Grun_RS 07-03-2010 08:48 PM
I see you checked for fuel. Did you check the actual pressure, it should be ~56psi +/- 2. If it's low, the pressure regulator may be tired.
If the AC is activated the fans would come on. If not, then yes something isn't right...
porsche4life 07-03-2010 11:34 PM
What thread is the cap on the end of the rail? I do need to check pressures.....
Yes I checked all the fuses.... I checked those before I threw in the towel and called dad to come tow me home... I don't like admitting defeat.
Grun_RS 07-05-2010 08:20 PM
Not sure what the thread is on the 44 - on the 968 it's 12 x 1.5mm. Unfortunately the proper adapters are only available in a master test kit, typically used by dealers. I checked with Porsche & VW and was unable to find the exact individual adapter. I have a 68 and ended up machining an adapter to fit a gauge.
Or you could go to a independent German shop and have them test it for you. Yet another option is to check out Lindsey Racing, they have a bolt on gauge.
porsche4life 07-05-2010 09:29 PM
Damn.... I was just in OKC today... Doubt they were open though...
We have an extra rail and cap... Considering drilling and tapping the end of it for a gauge...
porsche4life 07-10-2010 10:01 PM
Checked the Psi... Getting around 36psi while cranking... which is right per clarks garage...
I checked the injectors with a noid light. I am suspecting that they aren't getting a strong enough signal to actually fire though... Anybody got any idea?
968 GUY 07-11-2010 07:16 AM
I had that prob on the 951 once, removed batt cable for a couple of minutes and it started right up.
I had that prob on the 951 once, removed batt cable for a couple of minutes and it started right up. (after reinstalling batt cable)
desertt5 07-11-2010 03:45 PM
Mine was similar on my 944S. the last thing I did was clean the positive cables, including the little ones on the battery. Thye looked good, but did have a small amount of grey powder corrosion that came off.
Check DME yet?
porsche4life 07-11-2010 03:48 PM
I checked the DME... The cables look good but I suppose I will give them a good cleaning just to make sure....
porsche4life 07-16-2010 09:56 PM
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid282.photobucket.co m%2Falbums%2Fkk270%2Fjohnsonsl%2Fporschenostart.mp 4">
Its got spark... Noid light says signal at the injectors... The timing marks are good and the belt is good on tension.... :(
Techno Duck 07-16-2010 10:02 PM
Assuming you do have fuel and spark, time to check compression.
To check the injectors, you can pull the fuel rail off and stick each injector into a water bottle, crank the car and insure the injectors are actually spraying.
porsche4life 07-16-2010 10:07 PM
I'll try to get ahold of a compression gauge tomorrow.... Would it loose compression so suddenly? No milkshake either place...
The car literally died while I was accelerating... Went just past 4k and was about to shift and realized it flat lined....
968 GUY 07-16-2010 10:51 PM
If your car has an alarm system, it could be the problem, check clarks for alarm bypassing.
