jasonriverside's Avatar
Porsche Crest roof water drain tube
Alright... I have 968 water problems that have migrate to the rear of my sunroof... I fixed a detached drain tube in the front but have developed more pooling of water in the rear.
I tried air pressure to blow out the tube which was unsuccessful due to 'what I thought' was an extremely clogged tube... In the process it detached from the fitting at the sunroof. ((No big deal!!))
I proceeded to remove all of my body trimming in the area to access the tube and hopefully blow out the crud from the tube directly. I however discovered that my tube is actually pinched by the cross rod for the sunroof motor onto the body frame.
Now I have to resolve the following problems/concerns...
1) Since this is a really old tube I am afraid that it will crack if I try to form it back to a round tube shape
2) I need to figure out a way to keep it from getting crushed again
3) I am not feeling very ambitious about trying to replace the whole tube which seems to be encapsulated within the rear body structure.
Any and all advice would be greatly appreciated.
Old 06-13-2010, 01:26 PM
Aufenbahn's Avatar
Could you use the old tube to pull in a new one? The rear ones end up down in the cubby at each side/bottom of the rear compartment then out thru the bottom
Old 06-14-2010, 02:23 PM
Tags
drain tube rear roof
