-   -   I can't remember what goes in the holes each side of the knock sensor. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/547964-i-cant-remember-what-goes-holes-each-side-knock-sensor.html)
bebbetufs 06-14-2010 10:20 AM
I have two threaded holes each side of the reinforcement for the knock sensor and ICV. I can't remember what goes there. Am I missing something?
On the block in the picture the two circular protrusions have note been drilled and threaded.
http://karl.wilen.us/images/Rebuild/Engine16a.JPG
running_cold924 06-14-2010 11:10 AM
i think the one on the left is nothing......
bebbetufs 06-14-2010 03:29 PM
I think you're right. There is some dirt in the hole so it must have been left open. what about the right one?
running_cold924 06-14-2010 04:45 PM
that should be for: http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/528766-aos-question-while-your-there.html
the knock sensor
but my bad, the small little plate for the IAC valve goes in the first hole, or atleast that's what my pics show...
bebbetufs 06-15-2010 12:30 AM
Just to make sure we talk about the same thing.
These are the places where my block has drilled and tapped holes. I have a 90 turbo by the way.
http://forums.pelicanparts.com/uploa...1276587004.jpg
running_cold924 06-15-2010 09:51 AM
hmmmmm....not sure then. my 86 has nothing that goes in them. I don't think they re even drilled or tapped...
bebbetufs 06-16-2010 12:35 AM
probably nothing then....
