Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
callmethewander's Avatar
how do you remove ignition switch?
Anybody know how to remove the ignition switch? Or even just the cylinder? It seems like porsche tried to make it very difficult, it looks like they used some kind of breakaway bolts, anti-theft purpose i guess. anyway i want to change it because I lost my key (it's one of my projects, not a daily driver), i have a spare set of cylinders for the doors and the hatch also, i'm hoping they're a lot easier to change. thanks for any help.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 06-16-2010, 03:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
dunno about other years
but on 83, center steering wheel, then remove it. remove turn and washer stalks. remove column shrouds. unbolt the ignition cylinder
Old 06-16-2010, 04:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Hello, In order to remove the Ignition Key Lock cylinder you have to drill a 1/8" hole in the right location to release the spring. If you can all ready see the broke off torque bolts you must have the gage cluster out. The easiest way to remove the bolts is to use a Dremel Tool with a cut off wheel. Grind a slot across the end of the bolt (on top) so you can use a common screwdriver to turn the bolts back out. You can use common cad plate bolts and lock nuts when you re-install. Below is where you drill the hole. Put a small screw back in the hole.
Ignition Lock Removal
Cheers,
Larry
Old 06-16-2010, 04:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
thank-you, i should have said, it's a '91, i actually just have to get the housing out since i have a spare one, the dremel tool sounds good but i don't see how i'll be able to get it in there!
1989 S2
1988 S
1987 944 n/a (sold)
Old 06-16-2010, 07:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
o, and it has an airbag!
1989 S2
1988 S
1987 944 n/a (sold)
Old 06-16-2010, 07:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
OK,Go to the link below on Clark's garage. com. It will tell you how to remove the air bag. Disconnect the battery at the negative side and wait at least 30 min. before you disconnect the Air Bag. Remove the steering wheel and wiper control and the left side dash over to the HVAC controls. Once the Gage cluster is removed you should have enough room to use the Dremel Tool. If you find it still restrictive buy the flex end for the Tool. Anyway you look at it you have to be careful with the plastic dash parts esp. the small tabs you can't see as they will break. You can't be heavy handed or rush the job.
Late Model 944 Dash Replacement
Cheers,
Larry
Old 06-17-2010, 01:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
ok, thx Larry, I guess i'm in for a job. I'm really buggin out tho, 'cause i just had the keys, i just moved the car out of my garage and up onto ramps, let it run for a while and the next day i couldn't find the keys, i have no idea what i did w them, it's drivin me nuts and i'm afraid that i'll find them after doing all this work. another thought tho, how is porsche about making replacements, any idea?
1989 S2
1988 S
1987 944 n/a (sold)
Old 06-17-2010, 07:03 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
I'm 70 and when I forget what I did with something this works for me. I set down in my easy chair, relax, close my eyes and think back to what I was doing. It's like a replay step by step and visualize in my mind what I was doing at that time. Look under the floor mat, sun visor, and the arm rest. We are creatures of habit and don't think about what we do all the time. Check your pants pocket that you were wearing that day. If your wife has already washed them the keys may be on top of the washer. ACE Hardware normally has a key blank that fits.
I hope you find the keys.
Key, DIY on keys, ignition key, door key, gas cap key
Cheers,
Larry
Old 06-17-2010, 11:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Originally Posted by Grandad#3 View Post
I'm 70
Awesome.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 06-18-2010, 03:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
944Spec_bound's Avatar
I did that once, lost my keys when I was at school. Spent hours going to every class with the custodian, retracing my steps, nothing. Called my dad, he came and drilled and yanked the switch out with a slide hammer like the car thieves do in the movies. On the way home I reached in my jacket pocket, and there they were. It was a new jacket, and I'd forgotten about that pocket.
I threw them out the window and never had the nerve to tell anyone....until now. lol.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 06-18-2010, 10:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Thanks all, now if i can just find my easy chair... seriously tho i did that, i looked everywhere, several times, i'm thinking now that somehow they got thrown out, i was also cleaning the garage out after taking out the car, jump starting it and letting it run... I appreciate all the help.
1989 S2
1988 S
1987 944 n/a (sold)
Old 06-19-2010, 08:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
why not take the VIN to the dealer and order a new key?
it worked for me.
Tom
Early '85 944
Old 06-19-2010, 04:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
i think i will try that, although i'm not sure that it' s the original switch, but i think it's worth a try if it's not very expensive.
1989 S2
1988 S
1987 944 n/a (sold)
Old 06-19-2010, 08:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Toofah King Bad
Rasta Monsta's Avatar
I lost my Mazda key once and a mobile locksmith came to my house and made a new one by marking a blank with engineer's blue and hand cutting the notches. . .$25.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-20-2010, 10:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
wow, that's a deal!
1989 S2
1988 S
1987 944 n/a (sold)
Old 06-20-2010, 06:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
