Sachs struts
Whats available as replacement for them on an 89 s2 ,whether its a full strut ,insert or coil over ? For street use and no stupid prices !
Can u get a bilstein insert to fit? and what do Gaz di? as well as other makes Thanks Mark |
In the Fires of Hell.....
You need to do the "Hacksaw Koni" conversion with a 1414 insert or likewise, otherwise replace the entire strut on the late cars.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Hacksaw Koni conversion is about it...
Paragon Products - Tech Session - Porsche Tech and Information |
"Hacksaw Conversion" sounds much worse than it actually is. Here is a link to my Koni conversion on my '88 n/a.
Weekend Project Pics - Koni Inserts |
Thanks i dont mind modifing the struts, it seams easy enough to do , but are there any other makes available where u have to do the same mod eg Bilstein
Thanks |
