-   -   no spark (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/550045-no-spark.html)
jdb design 06-26-2010 08:29 AM
no spark
84 944s list of things already done,
new DME
coil
plugs
ref sensors
plug wires
ignition switch
checked fuses
rotor button
distributor cap
coil is getting power but from there none
stumped from there....
89-944NA 06-26-2010 08:50 AM
do you have signal at the injectors? have you jumpered the dme to test the fuel pump function?
jdb design 06-26-2010 08:52 AM
no signal at injectors< yes about the fuel pump, getting fuel to the rail
89-944NA 06-26-2010 09:02 AM
make a three wire jumper and jump the fuel pump to see if it is working. it could also be the dme relay, do you have a spare? Quite frankly, I am having a similar problem, I ran some errands the other day, and at my last stop (Porsche dealer), the car refused to start...had it towed home.
DME was just rebuilt (THAT is not the problem), checked the fuses, checked the relay, everything on the "won't start" checklist has been checked and still no start...now thinking it may be a faulty harness.
Also, one other thing to check..get under the car and have someone rotate the engine (slowly) and make sure the pins for the reference and speed sensors are still in the flywheel...I had one fall a few cars ago.
Good Luck, and keep me posted....I'll do the same for you.
jdb design 06-26-2010 09:04 AM
hey thanks for the info will try those things, will keep you posted
just checked with my mechanic, he said that the pins are good, leading toward wiring harness problem
89-944NA 06-26-2010 09:04 AM
clean all the grounds?
89-944NA 06-26-2010 09:05 AM
search this list, there is a "no start" checklist posted, and begin the troouble shooting process....lol
jdb design 06-26-2010 09:14 AM
will do
89-944NA 06-26-2010 09:25 AM
you amy also need to check the turbo postings for that checklist, can't remember exactly where I saw it
