PO Rant
Why the hell is EVERY fastener torqued to 1,000 ft lbs? Is that to make up for the lack of any mechanical skill, evidenced by your fondness of RTV and electrical tape? Or Exhibit B the 15 gallons of Gulf of Mexico mix I drained because you thought refilling solved a bad head gasket?
My stunt wrench is working hard for the money. Sadly, corrosion is not a factor. Just had to use a 4 ft pipe to get the lugs off...impact wrench already failed miserably. It took so much force that I was steering the car.
So anyone got recommendations for the bolts holding the caliper on? Can't get my pipe inside the wheel well, nor maneuver the impact in there Already tried interlocking two combo wrenches, still couldn't get it. I'm thinking a 3 lb sledge sounds promising but can't think of how to implement it. I am amazed through this whole rebuild I have only ruined one fastener, which was only ruined because my allen key broke off in it.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 07-06-2010, 07:56 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Lots of lubricant and some heat. lol Are the bolts hex head or allen? Try a socket and breaker bar for the hex, or a long allen, and bang on it with a rubber mallet...I did the allen/mallet and they finally came loose. If they are allen, make sure you hold the wrench all the way in, or you'll strip the shoulders. Good Luck
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-06-2010, 08:49 PM
rubber mallet = fail. Though if i get a bigger diameter pipe I can use if on an offset box end. Maybe if I crimp the wheel I can aim whatever tool I use out of the fender. Too late tonight.
I have to commend Porsche on the highest quality fasteners I have ever seen. Other than an exhaust bolt I twisted in half, which I planned on replacing anyway, I don't think I've even come close to misshaping anything. I've actually bent several autozone tools on this project without the use of my trusty pipe.
Old 07-06-2010, 09:52 PM
smokin_944's Avatar
I know how you feel... Torque wrenches are seldom used by POs. For the mounting bolts on the caliper I sprayed with WD40, let it soak 5 min. and used one mother of a pry bar. For this reason, usually when I do a repair on the car I replace all the bolts with factory replacements.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 07-07-2010, 06:03 AM
Misunderstood User
I'm with you on this. I recently did a brake job on my Benz. Had it at a tire shop to put new rubber on it. The maroon must have set the pressure to beyond infinity. I not only used my 18 inch breaker bar but a 2 ft pipe extention to loosen the lug nuts. OMG, I thought they would never break free.
I use PB blaster on all underbody fasteners. Heat works too.
I had to use my breaker bar to loosen the caliper bolts on my 944. My impact wrench didn't work. I also use impact sockets. As others have said, Porsche fasteners are better than most.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 07-07-2010, 06:35 AM
Going faster all the time
Litesonic's Avatar
second for PB blaster.... has helped me on a few cars.
The other PO rant I have is not bothering to put all of the fastners back on. My bat wing was there by 2 screws (that don't look like they know each other) and 3 zip ties. Sheesh.
Old 07-07-2010, 07:07 AM
Better than PB Blaster???
I have been told by those I trust, and a couple mechanics, that a bit of ATF mixed with Acetone (50/50) will allow you to remove any bolt. Might be worth a try.
Old 07-07-2010, 09:53 AM
968 GUY's Avatar
I put antiseize not only on the threads for the lugs but on the mating surface of lug nut. Of course I put it on most other fasteners.
Old 07-07-2010, 11:20 AM
Toofah King Bad
Rasta Monsta's Avatar
Welcome to the P.R.O.G.R.A.M.*!
rasta
*previous retarded owner's grievous repair attempt miscalculation
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-07-2010, 03:26 PM
I smear some regular old grease on any bolt I put back in. Not a lot, just enough to coat the threads w a film.
Old 07-07-2010, 03:27 PM
89-944NA's Avatar
I use KROIL on any seized/over tight fastener, then when re-assembling, I will use a new fastener and anti-seize, problem with grease on the calipers, is the heat melts the grease, anti-seize won't melt.
Semper Fi
Old 07-07-2010, 06:18 PM
89-944NA's Avatar
[QUOTE=smokin_944;5441764]I know how you feel... Torque wrenches are seldom used by POs.
I am currently dealing with a moron who used GREEN locktite on the bolts that hold the ref/speed sensor adjuster. FINALLY got the one on the "upside" of the adjuster out, but with the engine still in the car, I can't get the necessary torque nor the required heat to break the "downside" fastener loose.
Anyone got any ideas on that (kroil doesn't work on locktite)? lol
Semper Fi
Old 07-07-2010, 06:23 PM
Back from Beyond
I've had my 944 so long now that I'm the PO as far as repairs go. There is a certain satisfaction in going where you've gone before...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-08-2010, 04:36 PM
ideola's Avatar
Haha, now that's funny! Made me laugh!
Grease on fasteners is not a good idea as it will prevent proper torque and could lead to the fasteners loosening and then failing. Fasteners should be torqued wet or dry based on FSM specs. Wet should be with oil, not grease.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 07-08-2010, 06:28 PM
Man do I love that cloud of dust when a fastener breaks loose. Both calipers dissasembled well too and brake pads were close to new. Dust seal looks ugly, I haven't popped the piston out yet to look at it. Anyone know if the brake line connection is the same as on all motorcycles and ATV's? I like to use a spare hand brake on my bench to get the piston out.
ideola I learned that from a 40+ yr motorcycle and boat mechanic. It has never failed me on anything. Maybe you will prove me wrong, you do this more than I do. Until the day it fails me I will keep doing it though.
Old 07-08-2010, 08:39 PM
I've tried WD40 and PB Blaster for stuck bolts, but I can't say they've ever really helped. I have not found a substitute for brute force, but it is a bit scary when you are under a low car and the jack stands do anything but stand perfectly still and quiet.
Old 07-08-2010, 09:12 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Keep whacking the socket wrench with a regular decent weighted hammer. Back and forth until you get the threads to break free. Then whack to the right A ton of heat helps too. Using soakers never works for me. HEAT and BRUTE FORCE for the win.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 07-08-2010, 10:49 PM
Old 07-08-2010, 11:31 PM
968 GUY's Avatar
Beer always helps!
Old 07-09-2010, 05:30 AM
