Quick A/C filling question
I'm using a manifold gauge set. I have pulled a vacuum for about 1/2hr, closed the manifold valves and it has held for about an hour now. My question is: Do I start filling with freon while there is still a vacuum in there, or open the valve and release the vacuum first?
Keep the vacuum--it will "pull" the first can of freon.
Hook up the freon/pierce can and crack open the hose for an instant by the guages to remove hose air before you fill with freon. GL John |
Great, thanks!!
(I was thinking it might through off the PSI reading when filling) |
As you charge the first can you will see the low side jump to about 70-80 with the high side slowly rising, then the low will fall off. The can is near empty, move onto can #2 and let it go, when no more will release, close the low side valve, fire up the compressor, open the low valve, and let it suck the remaining 15-16 ounces in.
Edit: I forgot to mention that it is a good idea to crack the charge line (or depress the schrader valve on the gauges, if equipped) after you puncture the first and remaining cans. |
Wish Idda seen your post before I started filling it.
I turned on the a/c before filling, then I saw the quick rise on the low side. I was a little worried because the instruction card on the manifold said not to exceed 40psi. I got about one can and a half in there and it's already reading 275 high and 40 low. It's 90deg and about 80-90% humidity. I'm reading it at idle. Clarks chart shows it should be 35-40psi and 190-225 psi. I saw a post by John that says you should read the gauges at 1500rpm, not idle. I went back out and reved it up some, the low went down to about 20-25 and the high didn't change. I shut it off and stopped there. I guess my next step tomorrow would be to add more freon while watching the gauge at 1500rpm? Might the high side drop some? |
If you are using your gauge set correctly, and the high side gauge is not faulty, your high side pressure is too high and I would not suggest adding any more refrigerant. If the system does not have any air or moisture still in it (simply pulling a vacuum to 30 inches of mercury for 1/2 hour does not guarantee complete evacuation of non compressible 'gases') verify that your condenser fan motor is operating.
Remember when you charge a system with refrigerant: Liquid through high side only with engine off. Gas through either low or high side with engine off. Gas through low side only engine running. "Liquid" means can upside down. "Gas" means can right side up. How much refrigerant will you need, excluding that which you need to purge your service hoses? Look at the refrigerant sticker on the car, for example, if it says R12 '36' ounces, and you are converting to R134a, multiply the 36 x .85 = 30 ounces. This will be the 'general' starting point of the amount of refrigerant the system will use ... plus or minus an adjustment based upon a P&T or pressures and temperatures chart. PM if you need help. |
From what you just said about the can being upside down and right side up, I'm sure I did not fill it correctly. I'm going to do it over again this weekend, and pull a longer vacuum also.
If you attempt to push liquid refrigerant into the 'low' side of the compressor you can damage a reed valve and wash the oil coating out of the compressor.
If you attempt to charge into the 'high' side when the compressor is operating the higher operating pressures of the compressor could expand your little refrigerant can quite easily. Wear a pair of safety glasses to protect you eyes and a pair of gloves for good measure. Remember, if the system was low on charge the charge went somewhere along with the refrigerant oil, you need to add oil as well. Suggested Reading: Snap On Technical Training Systems - Air Conditioning , PN ACT279B Published by Mitchell International |
That brings up another question I had. How do you tell if you have enough oil in the system?
Actually that is a very good question. Time to think about this 'ey'!
Now what type of oil to use?: for R12 you can use either mineral oil or ester oil because the two types can live happily with each other. If the car has been converted to R134a and someone wisely put the blue sticker in the engine compartment documenting what kind of oil they put in and how much or you have repair record and they recorded it wisely on it, then you just have to use that type of oil. And, in this case I would play it safe by adding 4 ounces of oil and ignore how much may been injected with previous trials you have been doing. Here is the clincher, some TS Bulletins state to use 'x' or PAG, however most PAG oils and R12 mineral oil don't live happily together (like a bad divorce... LOL). Some little refrigerant cans can have either ester or PAG type oil. Maybe you know whats in there or maybe you are guessing. I'd rather not guess and end up with the Gulf in my ac system. So, if this is a 'real' first time conversion from R12 to R134a and you are using little cans of R134a and the can tells you what type of oil is in it, then I'd say I want 4 more ounces to play it safe rather than be sorry with a toasted compressor. On the other hand, if you don't know what you got and you want to save your compressor and lots of time down the road... then its time to liquid flush and for that I suggest you PM me with an email and note copy of this dialog attached. |
OMG, I broke 700 ! Send me a Becks will you
I had the system converted to R134 a few years ago by a shop, but they didn't put any stickers anywhere. (they also put the wrong adapter on the high side fitting, it's a quick connect adapter, but the smaller low side size.)
I had to take the compressor off to drill out a broken bolt in the front mounting ear. It was also not cooling well, so I didn't mind doing this job. When I had the compressor out, I dumped the oil in a cup and replaced it with the same amount of new oil plus a little extra. It's around 5 ounces of new oil. I used PAG 100. The R134a cans I'm using are DuPont Suva from Auto Zone. I read the can, (with a magnifying glass) and couldn't find anything that says it has oil in it. Should the 5oz I put in be enough? If I need to, is there an easy way to add oil? |
Short answer: you should be fine to go with your 5 ounces.
Long answer below: From our experience on a conversion or retrofit from R12 to R134a in 924s, 944 and 951 (all share the same ac system components), adding 6 ounces nominal of 'polyol ester' or Ester oil seems to provide enough lubricant to the system; this assumes you disposed of what ever residual oil that was in the compressor (by inverting the ports over a collection can, turning the outer hub several times and changing the position or angle of the compressor to assist in draining; typically you don't extract much oil from a compressor, an ounce or two would normal if any) and you have replaced the receiver drier. The issue with small cans of R134a (vs. a 30 lb container) is that some retail brands have optional additives such as refrigerant oil, sealants or 'enhancers'. Frankly sealants should be avoided as studies have shown they can clog up other things besides leaks in a system, such as your expansion valve and compressor. I have yet to observe any performance gains from 'enhancers' (I guess we have to set up a lab for that one... LOL). But back on the subject of oil additives the question is what kind of oil? Is it PAG or Ester. If contained in the small retail can the additive should be noted on the can; you could search the MSDS (Material Safety Data Sheet) on the product however MSDS on retail packaging sometimes can be a headache to locate; you may find the chief component but not the additive noted on data sheet). The issue with systems having R12 'mineral' oil (naphthenic, paraffinic, and alkylbenzene) is that it has a very poor solubility with R134a. Since the compressor does not have a sump to hold oil the system relies on the refrigerant flow from and back to the compressor to carry oil through the compressor to lubricate it, hence the oil must be soluble or blend in with the refrigerant. The first conversions from R12 to R134a used PAG. PAG lubricants can come under attack from chloride residue trapped in residual mineral oil (such as in the drier, hose lines, compressor and evaporator) in systems that previously used R12. The PAG or its moisture content may also affect compressor materials. So an extensive cleaning or flushing of the system was required. With the introduction of Ester oils it was found that esters are not as sensitive to low or residual mineral oil concentrations; esters get along better with mineral oil. Some compressor manufacturers specify PAG and some Ester, it all depends upon when they did their studies. However we have been using Ester for retrofits for the past 15 years with little if any problems. Problems encountered with converting from R12 to R134a fall into two categories: The first is performance. On front condenser cars such as early water cooled Porsche's (924s, 994 family and 928) we have experienced little if any performance loss. On air cooled Porsche's (911,930) the performance problems are from the inadequate existing design (insufficient condenser and evaporator) On the water cooled cars a drop in observed performance is usually caused by not following procedure, such as adding too much oil which insulates the heat transfer in the exchangers (condenser or evaporator), inadequate evacuation (leaving residual R12 trapped in the residual oil, moisture or air), under or over charging. The second problem is component failure, typically a crashed compressor. In most cases the compressor was old and worn to start with, or there was metal particle contamination in the system, residual 'funk' (bad oil junk) or poor oil flow. Follow the right procedures and you should be successful. |
kuehl,
Please correct me if I am wrong. The correct PAG oil used for our conversions should be PAG 46 which is the interchange for the oil Porsche uses--ND-oil 8. The PAG oil used by marco was PAG 100 and this may be too thick for our compressors. Also, the oil should be put in different components. 2 or 3 ounces in the compressor, an oz in the dryer, and ounce in the condensor and if possible an ounce before the evaporator/expansion valve (or it may never get there) If marco put 5 ounces in the compressor, he has to spin the compressor free hand a many, many, many times before starting to avoid damage to the compressor. Even still, there may be damage to the compressor with use of the wrong weight of PAG oil. John |
ND8 vs. PAG46 I am not a favor of PAG because of the issues noted. "ND 8" has been quoted from various sources to be same viscosity as PAG46 however I have not compared the two data sheets from various manufacturers or private brand suppliers to verify it. But, we'll assume it is for sake of bandwidth. The PAG oil used by marco was PAG 100 and this may be too thick for our compressors. Maybe. You could run a side by side study on 'new' identical compressors under identical conditions and compare the outcomes. I would be concerned if the evaporator core temperature was low. Also, the oil should be put in different components. 2 or 3 ounces in the compressor, an oz in the dryer, and ounce in the condensor and if possible an ounce before the evaporator/expansion valve (or it may never get there) I would never waste my time with such a strange procedure since the oil and refrigerant with become homogenized throughout the system shortly after running it. Oil is usually introduced, or simply introduced, into the system by simply putting the required amount into the compressor (DIY), or having your ac tech inject the oil after evacuation. If marco put 5 ounces in the compressor, he has to spin the compressor free hand a many, many, many times before starting to avoid damage to the compressor. Your probably referring to possibility of 'slugging' compressor's reed valves, which can occur with a heavy oil load or when you mistakenly put liquid refrigerant through the low side. Usually a few hand turns is enough move excessive oil past the reeds but many have not and have not damaged the reeds, but a good concept to follow in practice. Even still, there may be damage to the compressor with use of the wrong weight of PAG oil. The condition of the compressor prior to doing any procedure is normally considered by those who have 'been there and done that'. A savvy DIY would consider the mileage of the compressor and inspect the compressor ports and residual oil for signs of contamination. Where is my Becks? |
704 posts and you expect a Becks-----maybe a wine cooler. You are from the class of '04, not officially an 'ol timer ;)
I understand your use of esther oil. It mixes better with R12. If the system is not flushed correctly esther oil should be used. marko used PAG 100, this is why I wanted your opinion on the weight of the oil. AutoZone sells PAG in 3 weights (46-100-150) ---on the same shelf----you could accidentally grab a can of PAG 150 without looking and use it-------------BTDT. The compressor will overheat or the oil will clog the system. Filling oil. If the compressor is off, and PAG 46 is chosen, the compressor should be rinsed with new PAG 46----not AC flush and refilled with 2-3 oz of PAG 46 A new dryer should get 1 OZ The condenser should be properly flushed with a cheap can of AC pressure flush (~$20) from AutoZone to get the residual R12 mineral oil out of the bottom line. Pros-kuehl, have a solution in bulk--maybe some denatured alcohol. After the condenser is flushed new "O" rings used (AutoZone small pack $6) and insert an ounce or so in the condenser. You should replace the 4 "O" rings on the compressor manifold--get 2 small packs of "O" rings. Stick another ounce in the condenser discharge line to the evaporator. This is my procedure. It may be a waste of time. I do understand the Professional AC technician with the quality of tools and unknown voodoo machines used will consider this overkill. On the forum, I revert to a basic technique that a garage, novice experienced, member can understand. Thanks kuehl, cheers! John |
704 posts and you expect a Becks-----maybe a wine cooler. You are from the class of '04, not officially an 'ol timer maybe on this forum 04... , I guess
I'm not qualified to answer ...LOL , Sorry, no wine coolers are allowed in our facility. I understand your use of esther oil. It mixes better with R12. If the system is not flushed correctly esther oil should be used. Most DIY questions that you will read on forums never address 'flush' and I doubt you will find any majority doing it, hence ester. marko used PAG 100, this is why I wanted your opinion on the weight of the oil. and? AutoZone sells PAG in 3 weights (46-100-150) ---on the same shelf----you could accidentally grab a can of PAG 150 without looking and use it-------------BTDT. The compressor will overheat or the oil will clog the system. maybe! but doubtful, most DIY will hit a big-box store and big-box stores normally limit inventory to 46 or 100 Filling oil. If the compressor is off, and PAG 46 is chosen, the compressor should be rinsed with new PAG 46----not AC flush and refilled with 2-3 oz of PAG 46 I would be interested in hearing on how you are going to successfully "rinse" a compressor. A new dryer should get 1 OZ Your reflecting upon the estimated ratio of oil required for each component. How would you handle an unknown system, one that has no documented history? So far with the compressor and drier you are only up to 3 to 4 ounces total system based on your procedure. If the system has had a terrible history, which is common on 944's based on the ownership turnover you are going to have a problem with only 3-4 ounces way down the road. The condenser should be properly flushed with a cheap can of AC pressure flush (~$20) from AutoZone to get the residual R12 mineral oil out of the bottom line. Pros-kuehl, have a solution in bulk--maybe some denatured alcohol. The issue that arises when using flush agents that are not compatible with the refrigerant and its oil, problem is residual flush agent. For instance, I recall a chap who liked Tri-hlor 111, the problem is it permeates into the rubber hose and then mixes with the refrigerant to form a funky gas that does not have the same characteristics as the single component refrigerant. After the condenser is flushed new "O" rings used (AutoZone small pack $6) and insert an ounce or so in the condenser. You should replace the 4 "O" rings on the compressor manifold--get 2 small packs of "O" rings. Well we are up 4-5 ounces of oil. Looking better for sure. Although it is better to replace the stock o-rings with a HNBR (hydrogenated nitrile rubber) when converting to R134a, the rule is "if it has not been opened you typically don't have to replace it" because it is a static seal and the surface that is exposed to refrigerant is limited. But if you have the time 'go for it'. Might as well note the sizes why we are here: Compressor hose connections: (1) #8, (1) #10 Drier: (2) #6 Condenser: (1) #8, (1) #6 Expansion valve inlet: (1) #6 Expansion valve outlet: (1) probably #8 (have fun changing this one based upon the model year) Evaporator outlet: (1) #10 Compressor manifolds: on a 10P15E or 6E171 (4), WA when I get my beers. Stick another ounce in the condenser discharge line to the evaporator. Get out the syringe boys! This is my procedure. It may be a waste of time. I do understand the Professional AC technician with the quality of tools and unknown voodoo machines used will consider this overkill. On the forum, I revert to a basic technique that a garage, novice experienced, member can understand. Voodoo machines? Is that what we call those little rice rockets that pull up next to us at the light? Thanks kuehl, cheers! I can't toast cause you ran up a tab here. John |
Thanks again kuehl,
We have raised some additional questions that certainly has marko scratching his head. I will now go in a corner and welcome your advice. John |
I was driving down a country road once and past a sign in front of church.
The background they had painted in had a shadow of book and the foreground big bold letters. As I drove away all I could say was 'friggin fantastic advertisement!' What it said kinda applies to everything we 'should' do. It said simply..... Read the Instructions Suggested Reading: Snap On Technical Training Systems - Air Conditioning , PN ACT279B Published by Mitchell International |
Interesting, although I take the necessary steps with other's vehicles, I can accept compressor failure when I do things my way, on my own cars. My attitude towards the whole ordeal mirrors how I feel about timing belts, why make things complicated, it's a rubber belt.
Through my own testing, mixing oils makes not one bit of a difference. We have an a/c tech within our corporation that helped design a/c systems for several manufacturers, he'd probably say I'm wrong and catastrophic failure is inevitable. I'd tell him the background on my system and offer a ride. I remain on the side proclaiming that it's a bunch of bs, and that will most likely be where I stay until we see shade tree results with the incoming hfo1234yf refrigerant. Do what you want. |
Should I start a new thread or just hijack this one?
I have an 85.5 944 with bad compressor o-ring seals and a lot of oil leaked out. I have a seal kit and a new receiver dryer. I was planning for Freeze12 refrigerant. I will replace any disturbed o-rings. How much oil should I add? Seems like all oil in the compressor leaked out. I can only assume the sytem has what is left of the original oil type in it. I would like to make this a permanent repair so going to a little extra trouble flushing and re-oiling etc wouldn't bother me but if I can just put in a few ounces of oil X instead... thanks! |
replacing drier and compressor on a 944, use 6 ounces , you could go as high as 8
Info on Freeze 12:
If you take your Freeze 12 converted car to a shop for an AC repair you cannot fix, they may not work on it. John |
It depends, if the front seal went fast, then be liberal with the mineral oil during assembly after cleaning all the parts. Coat the new seals well too. You can run through an 8 oz. bottle when you knock it over.
These compressors weren't sent to Germany dry. They probably were full, but assembly capacity prior to testing was probably 1-1.5 oz, then they added more later. Take a close look at the shaft where the seal rides, it has to be smooth, if you can't get it there with 220, it's gone. I'd recommend adding 2-3 ounces following assembly, but I know nothing of the amount lost. It's a judgment call. How did the compressor look after failure? I stay away from Freeze 12, but people have had good luck. YYMV. I'd invest in a low side R12 to 134 elbow fitting, rebuild with pag 46 and charge to around 27-29 ounces of R-134a. While you are taking the time, it would be wise to clean the condenser. What ever means it takes, but don't use a pressure washer. The best way is to remove the radiator first. |
MVAC Refrigerants Fitting Sizes & Label Colors | Alternatives / SNAP | US EPA You'd be surprised as to how many people (DIY and service techs), "unknowingly" of the potential outcome, forget to put a label on the car or swap service port adapters. A service tech could unknowingly recover the unknown refrigerant into their R12 machine and that would contaminate their refrigerant recovery bottle..... meaning they would end up with mixed gas which is a NO NO in technical terms as well as EPA regulations. Most tech's don't have refrigerant identification equipment. Yeah, if I was the tech I'd be pissed for sure. |
That's a good point. If you do the work yourself and decide to sell, label it. I've left the high side fitting alone, it's still R12. It doesn't matter to me because I have both sets of gauges. I consider it an insurance policy where it might keep someone from messing with my system, if I were ever to have a shop do other work on the car.
Some places are quick to hook up the gauges to see if they can bend you for more $$. They'd balk when they see what I have and haven't done. The first thing they see is R12, but it's clearly not, if they are smart enough to look at the low side, let alone find it. If they pull it out and contaminate their R12, tough shyte. They shouldn't have been messing with it. |
My suggestion, just based on all the phones call I get where I ask "So, is the car converted to an alternate refrigerant, what kind, how much did you use, what kinda of oil, how much oil, what were your low and high side pressures at idle and the ambient?" At the minimum write it all down and store the notes in your glove box.
Putting the proper conversion sticker on the car along with the data (oil type, amount, refrigerant amount) will remind you too. If you going to a tech and they are 'quick to hook up gauges' and balk at you? Well, in that case then you are seeking help and when you are seeking help you gotta be up front with them and at least "listen" to what they have to say. You never know, you might learn something listening or at least you'll get an idea with respect to getting a quote from them if you choose to go that route.... and, at least pay them for their time and effort, you never know when you might have to go back and revisit them. |
It looks like I hit upon some very good advice. Since the overwhelming opinion seems to be that 134a works well enough (pressures don't get too high) and is the simplest route I will try it and see how it goes. When I pull the compressor, I was only planning to replace the case o-rings and not the shaft seal but I will look at this aspect as well to make sure I am not overlooking something. The advice on oil seems to be I can add 6-8oz PAG46 (for compressor and dryer) distributed around, to the original oil in the system without flushing. Also clean condensor, oil all seals, low side elbow fitting. Do I have all of this correct?
Many Thanks! |
OK, kuehl is a Jersey boy on the golf course having his xxx Becks and matt is in Texas probably with his head stuck in a BMW hood working on the AC in the repair shop. Your post said you lost a lot of compressor oil. You thought it was the line "O" rings. You were going to see if the front seal leaks. Do you think you may have more leaks and the compressor should be totally resealed? Do you have a new receiver/dryer? Pelican $11 each or so----must do. TIP-Pelican sells a HUGE seal kit with the conversion caps and new valves you should also replace--they get old and leak. http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=55-9807-901-M325&catalog_description=R%31%33%34a%20Retrofit%20 Kit%20Contains%3A%20R%31%33%34a%20Charging%20Adapt ers%2C%20O%2DRings%20and%20Required%20Label%2C%20% 39%32%38%20%28%31%39%37%38%2D%39%35%29%2C%20Each%2 0%20%20 My opinion, If you have already taken the hoses off the compressor to change the "O" rings, you should just remove the compressor and turn it upside down to see if "all the oil did come out". Be careful of the coil wire connection. Do not pull on it--gentle. Usually nothing will but it will satisfy your curiosity. It may not be necessary but with the compressor on the bench you could change the 4 manifold "O" rings. Again your choice but why not. If you need "O" rings, AutoZone sells small kits---usually 2 will do--about $6 ea. or find a store that will sell individual "O" rings for R134a usually green or light blue/green. kuehl asked how I flush a compressor-----matt suggested I pour in some PAG and turn the pully a number of times and then pour every thing out-do not reuse. It will never be perfect but it is a little satisfaction. Never use AC flush. You might read my earlier post where I suggested to flush/backflush/repeat the condensor to remove the old oil that sits in the bottom tubes and causes poor circulation if not removed. kuehl thought it may not be necessary. Then measure some PAG and put in slowly about 3 or 4 oz if you can. If you can get more in, add a little more. Keep track of how many ounces you put in. Keep an ounce or so to pour it in the receiver/dryer---another for the condensor if you flush it. -Do not open the receiver/dryer rubber caps until you are ready to fill and install. This should give you about 5 or 6 ounces of oil, maybe more depending on how much you got in the compressor. kuehl thinks 6 to 8 is sufficient. Remove and replace the receiver/dryer and mount the compressor. Attach all lines and tighten to spec. Yes, put PAG on all new seals to prevent seal "roll". IMPORTANT Now you have to spin the compressor many, many, many times to get the oil out of the compressor and into the system. A compressor does not move oil----it moves vapor. KEEP SPINNING Now hook up the belt, attach the coil wire and cross your fingers. I am sure I forgot something. GL John |
Welp, I started over today. Replaced the drier, ran vacuum for 1hr instead, pressure washed the condenser. With what I believe is the right amount of oil and freon, temp at 90deg, box fan in front of the car, radiator fans at high speed, rpm at 1500, I get 32 low, 260 high, vent temp at 60deg with windows rolled up, recirculate on and fan speed at 2.
If I spray a mist of water on the condenser, the high temporarily drops to about 245. Does it sound like I might need to flush the condenser? |
| All times are GMT -8. The time now is 09:57 AM. |
