M030 Sport suspension advice
![]() I have a very nice 87 924S I am considering autocrossing. It has the M030 sport suspension that has Boge (??) shocks that need replacement. I have a used but good set of Yellow Koni front struts I want to swap into the car. I would buy new matching Konis for the rear. Is this the correct way to go? Also wonder about the color code dot on the front springs.........what are the different spring rates available? The springs on the Konis appear to have white paint dots. Thanks in advance. Len ![]() |
![]() Well I pulled the front wheels and discovered the Black shocks (Boge???) have adjustable spring perches. Anyone tell me what these are? Can I buy inserts for these shocks? My yellow Konis have fixed spring perches and I would rather have the adjustable ones. Len ![]() Last edited by BoxsterGT; 07-07-2010 at 01:50 PM.. |
In the Fires of Hell.....
924S'es are kind of weird animals. Pelican says that you can buy inserts for Boge struts for your '87 924S, but doesn't mention anything about an M030/Club Sport option.
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=115-153-M10&catalog_description=Front%20Gas%20Boge%2FSachs%20S hock%20Insert%2C%20for%20F%26S%20Strut%20only%20%2 82%20per%20car%2C%20sold%20individually%29%20944%2 0%281983-86%29%2C%20924S%20%281987-88%29%2C%20Each
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Perhaps you could put a Koni insert into the front shocks to keep the adjustable perches? Not sure on a 24.
~Chris 1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear 1993 Jeep Cherokee - 3" Lift, 30" tires |
Toofah King Bad
M030 strut assemblies are Koni, and are $850 new here at Pelican. Paragon Products offers a rebuild service to replace the internals with new Koni inserts. Finally, if you ship them to Koni or another rebuilder to be refreshed.
Personally, I just did the Paragon option and was pleased with the results.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
