gas/shifting jerking
ok, whenever i left off the gas, my car pulls back a little hard like i let off the gas really hard...even if i try to let off the gas as slow as possible it still does it a little bit. why? i think it may have to do with the clutch b/c it seems that i have some backlash and nosedive when i shift hard and a little backlash even when shifting smoothly.
Old 12-26-2001, 07:29 PM
stray15's Avatar
Send a message via AIM to stray15
Why in the world would u ever want to lift of the gas?
Porsche, through and through
Tim
'83 944
My Photo Page
My Home Page
Old 12-26-2001, 07:41 PM
Bay Area Patriot
TheStig's Avatar
hell yeah WOT ALL DA WAY!
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 12-27-2001, 12:20 AM
New year, new clutch time!!
Pull off the rubber plug at the front of the transmission, put your hand ionside the hole and grip the driveshaft ... if you can twist it..new clutch required.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-27-2001, 10:22 AM
well, i just replaced my master cylinder and i didn't have time to bleed the clutch all the way..it still has a little play in it. also, the clutch seems sticky or slow. it's not smooth, you can't gently release it fast. if you try to pull off slow, you kind of have to wait for it a litle to come up..could those things have anything to do with it?
Old 12-27-2001, 11:57 AM
No, the actuation of the clutch has nothing to do with the backlash problem. But when you replace the clutch make sure you do bleed the system properly..you should always replace the master and slave cylinder at the same time.
Old 12-27-2001, 12:08 PM
