LonyB's Avatar
Vacuum Leaks, Help!
Rebuilt the head, and got everything back together but I have vacuum near the collector of the intake that I can here but can not see.
Is there a hose under the intake where all intake tubes come together that I could have missed?
What should I use for intake gasket sealant? (PO had sealant on intake, indicating a problem, maybe?)
Old 07-12-2010, 05:55 PM
There should be a diagram of your vacuum hoses on a plate in the engine bay - passenger side towards the headlights. Without your year/model in your sig its hard to say anything specific about what goes where.
No sealant for the intake manifold, just the gaskets and 15 ft-lbs. I had a couple vacuum leaks so I tore it all out and ran new lines. Costs about $15 with connectors and a lot easier than chasing ghosts.
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 07-12-2010, 06:07 PM
yarfk
kfray's Avatar
Vacuum information:
http://www.clarks-garage.com/pdf-manual/fuel-13.pdf
http://www.clarks-garage.com/pdf-manual/fuel-14.pdf
http://www.clarks-garage.com/pdf-manual/fuel-15.pdf
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 07-12-2010, 06:39 PM
LonyB's Avatar
Update!
Thanks for the input but.....
As I had asked "Is there a hose under the intake where all intake tubes come together that I could have missed? " The answer was yes. In my haste to put things back together I forgot the 3/8" hose at the bottom of the collector that connects to the Idle Speed Control. All is back as it should be and the car is running great. I just wanted to add this for informational purposes.
Old 07-13-2010, 01:29 PM
