Need help. Cr1 radio unit problems
Blaupunk cr1 head unit gets power and lights up but no numbers displayed and no sound. Could it be because of a battery replaced? If so I have the code but no instrutions on how to input it. Thanks in advance, Really would like some help please! |
If it is an "anti-theft" model, then you will have to input the code to make it work any time the constant +12V supply is removed from it, such as when replacing the battery in your car.
Blaupunkt has manuals for all their models online, but I didn't see any CR1 listed. Maybe you left off a digit or two. You can check them here: http://www.blaupunktusa.com/pdfs/pdf_library.html |
thanks todd but i'm not even getting the word code. It has the lights when I turn it on but otherwise nothing. The tape wont go in and no numbers are displayed. Obviously no sound either. Could this be a fuse? I know I have a fuse box under the hood. Is there another fuse box inside the car?
| All times are GMT -8. The time now is 06:58 AM. |
