-   -   Rusty front rotors..no problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/553743-rusty-front-rotors-no-problem.html)
P944GUY 07-17-2010 01:43 PM
While waiting for parts to install my new KONI front conversion on the struts I tackled a few cometic issues,,,easy to clean up your rotors if you dont have the ones with the coating on them...a power drill and a good wire wheel..about and hour each side..and really shined up the calipers too....
http://forums.pelicanparts.com/uploa...1279399267.jpg
http://forums.pelicanparts.com/uploa...1279399296.jpg
http://forums.pelicanparts.com/uploa...1279399324.jpg
Techno Duck 07-17-2010 01:44 PM
Hope you wore atleast a dust mask :).
Give them a coat of high temp paint if you want to keep them from rusting.
Tidybuoy 07-17-2010 02:50 PM
Your rotors look great but I would recommend putting on a coat of paint on the rotor hats or they will be rusted in just a few months.
The factory spec is to paint with grey primer and then a light mist of silver.
I did mine and it took about an hour to remove and paint - I reinstalled in the morning. I did this a couple of years ago and they look as good as new today.
Here's some photos of my project:
New Rotors after about 4 months had rusted hats:
http://forums.pelicanparts.com/uploa...1279403124.jpg
After painting the rotor hat:
http://forums.pelicanparts.com/uploa...1279403171.jpg
Made a paint shield out of a manila file folder:
http://forums.pelicanparts.com/uploa...1279403198.jpg
Installed:
http://forums.pelicanparts.com/uploa...1279403311.jpg
ERAU944 07-17-2010 03:54 PM
you'd better take care of those calipers (and rotor hats) or they will rust like a b*tch. the calipers are cad plated from the factory, and when you strip the cad plating, you open them up to unmitigated oxidation. i'd go with black caliper paint, because i like things understated. some prefer red. to each his own! the rotor hats look good painted, but i'm not that into making my car perfect... i'd rather go drive. vroom!
fmartenies 07-17-2010 03:59 PM
I started rebuilding my calipers one night this past week...wire wheeled the rust of the non-aluminum parts. I had rusty boogers for 3 days. +1 on dust mask.
Dean924s 07-18-2010 10:57 AM
The rusty buggers wont kill. Breathing the dust from your brake pads is a whole different problem.
89-944NA 07-20-2010 05:06 PM
eeewwwwww brake pad dust...sure hope you had asbestos free pads
